Old 01-30-2012, 07:01 PM   #31 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...so, you're converting "pulses-per-unit·time" into "pulse-width modulation" (PWM), correct? Is that what the display uses?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 01-30-2012, 08:48 PM   #32 (permalink)
you get pulse width variation by default on my circuit ,(so you need to count the 0 volts "on" time of the output) , which is the same as a fuel injector signal but a lot less pulses & that is where my problem lay ,with the sensors I have previously tested .
The speed sensor I assume just counts the change from 12 volts to 0 volts & not pulse width.
Still no hot weather to test vapour issues ,February is traditionally the hotest month here ,mostly high 30's so here hoping.
Old 01-31-2012, 04:47 AM   #33 (permalink)
My way is the low way
Superturnier's Avatar
MyoldFord - '65 Taunus 20M Turnier
90 day: 31.32 mpg (US)
Plastic Spaceship - '94 Espace
90 day: 24.03 mpg (US)
Greetings from the opposite side of the globe!
February is usually our coldest month here. Now we have -15*C and plenty of snow.
I took this picture once I was coming from work by bicycle.
Thanks for the schematic! I might use that for my speed sensor.
I think you are right that you can get pwm from your fuel sensor since paddlewheel speed will wary. But I would think it would be more accurate, if you could modify the MPGuino code for counting the amount of pulses.
Summer vehicle
My dad's tire pressure is much higher than your dad's!
Old 02-02-2012, 06:16 AM   #34 (permalink)
Hi Superturnier
Yes , I agree with altering the software to suit the sensor ,but from a previous post ,I have read , that isn't going to happen anytime soon ,unless of course , I learn something about writing software ,I would like to , if I had some more free time.
I was hoping ,to come up with a simple solution , so you can swap the mpguino between Fi & Carb vehicles .
The weather here is similiar to Los Angeles, -15 too cold for me ,even in car.
Old 02-02-2012, 06:39 AM   #35 (permalink)
I have done some small modifications to the MPGuino code to suit better for my needs, but nothing big. Mainly copy +paste things.
Although I do automation software for my living I'm not so familiar with the MPGuino language. I guess it's some kind of C+ or something. I wish I could learn it more, but my free time is also too limited
I agree, many times it's best to keep things simple. It would be nice to have a solution also for the carburetted vehicles.
Summer vehicle
Old 02-08-2012, 06:51 AM   #36 (permalink)
This is the latest mod to my fuel sensor ,it now has 4 hall effect sensors .
I am hoping to improve the output at idle ,for a steady gph reading .
The 2 sensor version seemed to be consistent as far as final tank readings go ,but the instant display was all over the place.
will do some tank testing over the next week.
Old 03-07-2012, 05:57 PM   #37 (permalink)
Update for the previous mod to my flow sensor.
This sensor , I am now sure ,that they have got the rating confused & it should be rated at 2-30 litres a minute not 2-30 litres an hour as the data sheet states .
After much modding of this sensor ,I am going to call this one not suitable at this time as we need something that is simple .
I am looking at other methods to measure the fuel flow,including the sensor from Conrad.de .
Tp
