Old 05-21-2008, 08:41 PM   #161 (permalink)
dcb
Don't Panic
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Is your code posted somewhere? I've got the rs232 elm thing and a serial duino, I could at least see if it works any better for me, especially if it works with a guino compatable LCD hookup. Eventually I'd like to dissect my rs232 thing and package the elm chip with a duino, but for now it is rs232.
Edit: you might want to start a guinobd thread or something to collect the obd bits.
"I kicked a giant mouse in the butt! Do I have to draw you a diagram?"
Old 05-21-2008, 11:24 PM   #162 (permalink)
silverciv - '01 Civic EX 2dr
90 day: 36.13 mpg (US)
Well, I never got past a few tests.
I was using some test code which simply requests RPM when a button is pressed. It also uses my serial LCD using the software serial library.
Before I experienced some hardware problems, I could send ELM specific commands and receive the output but, the OBD commands would result in "BUS INIT:...>" with no error or anything but then the next command would do the same thing.
Code:
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
#define fButtonPin 4
#define keyWait 200
SoftwareSerial LCD = SoftwareSerial(rxPin, txPin);
void setup() {
  // define pin modes for tx, rx, led pins:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // start serial connections
  LCD.begin(9600);
  Serial.begin(9600);
  // setup button and turn on the internal pull-up resistor
  pinMode(fButtonPin, INPUT);
  digitalWrite(fButtonPin, HIGH);
  // set ELM to formated data
  Serial.println("ATFD");
  // turn off command echo
  Serial.println("ATE0");
  LCD.print("?a?fELM OUT:?n");
  // reset the ELM
  Serial.println("ATZ");
void loop() {
  char temp;
  // if there is something waiting on the serial connection, get that and send to LCD
  while(Serial.available()) {
    temp = Serial.read();
    LCD.print(temp);
  // if the front button was pressed, send the ELM command
  if(digitalRead(fButtonPin) == LOW) {
    delay(keyWait);
    LCD.print("?a?f"); // clear the LCD and reset cursor
    Serial.println("010c"); // ask for the engine RPM
Old 05-21-2008, 11:28 PM   #163 (permalink)
dcb
Don't Panic
dcb's Avatar
Aha! The serial LCD is conflicting with the serial elm323?
Edit, oops, no different pins. Let me see if I can adapt it to the parallel lcd...
Edit 2: That SoftwareSerial looks handy.
Old 05-21-2008, 11:39 PM   #164 (permalink)
It doesn't work very well for receiving because it doesn't have Serial.available(). Instead, Serial.read() waits till it has input.
Old 05-22-2008, 12:38 AM   #165 (permalink)
dcb
Don't Panic
dcb's Avatar
Ok, well I'm getting something.
the first 010c gives me the BUS INIT:
but the subsequent 010c calls are giving me a string with some hex numbers on the end that seem porportional to RPM. There are some strange characters in the string, but definately a rpm signal too.
Hmm... Have you tried any other OBD devices on your car lately?
edit, also, the E0 is being reset to E1 by the ATZ.
Edit, also the bus can take a little while to initialize.
Old 05-22-2008, 10:04 AM   #166 (permalink)
The only OBD device I have used on my car was the ELM323 connected to a computer and it worked with no problems.
I hope to do some work on it tonight.
So, you were using the Serial Freeduino with the RS232 connector connected directly to the ELM's output. I may have to get a Serial Freeduino to give that a shot if I can't get my Deciema with MAX233 to work.
Old 05-22-2008, 10:14 PM   #167 (permalink)
I got my hardware working again. If others are attempting the same thing, make sure you note that the MAX233 needs to have the internal capacitors wired differently than the MAX233A.
I am still getting the same issue with bus initialization. I don't get an OK or FAILED. I just get the prompt character again and then it repeats on the next command.
dcb, could you post the code that you used or message it to me.
Old 05-27-2008, 12:52 AM   #168 (permalink)
dcb
Don't Panic
dcb's Avatar
I couldn't PM it to you, it was too big, it was basically your code grafted over mpguino for all the parallel lcd stuff. Given the strange characters I saw, I wonder if a test with laptop receiving the data from the duino via the softwareserial object, instead of the lcd, might help narrow down the problem.
I'm sure you have tried other pins for SoftwareSerial.
Old 05-27-2008, 10:54 AM   #169 (permalink)
Hmm, I don't get any strange characters. My communication with the ELM appears to be perfect but, the ELM's communication with the car ceases to work when I am connected to the arduino, it works just fine however, when connected to the PC.
Old 05-28-2008, 10:16 PM   #170 (permalink)
dcb
Don't Panic
dcb's Avatar
I just wonder if there is a way to rule the softwareserial out.
Like teach pin 13 LED morse code instead and send the data there without the LCD or anything else but the elm connected?
SuperMID - Fuel Economy Display SVOboy Instrumentation 11 Yesterday 04:27 PM
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 11 05-08-2009 02:04 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 07:26 PM
What features on your ULTIMATE fuel economy instrumentation? MetroMPG Instrumentation 17 05-04-2008 11:16 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
