Old 03-17-2008, 11:08 AM   #21 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
The Arduino has serial output (and input - that's how it's programmed), not sure about the other platforms mentioned so far.
Old 03-17-2008, 11:28 AM   #22 (permalink)
Originally Posted by trebuchet03 View Post
That's just me, as someone with limited experience with microcontrollers - which is very likely the case for someone that is going to replicate any efforts.
Originally Posted by LostCause View Post
Look at the simplicity of the design compared to the arduino. No pre-etched board and just a bunch of components that can be bought at once from Digikey, Mouser, etc.
I'm with Trebuchet, because of my experience with this stuff ( = nil).
The thing that appeals to me about the Arduino is that it's ready to go, and I understand the programming process - plug it into a PC serial port and install the code.
I wouldn't know where to begin if I also had to select components & make the platform.
How is an atmega or other IC programmed?
Old 03-17-2008, 11:30 AM   #23 (permalink)
dcb
Don't Panic
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I think it has to have some kind of display, and an instantaneous and at least one resetable trip readout, to be a really useful "learn how to drive again" tool.
So at a minimum it:
1. has instant MPG displayed at all times.
2. has trip MPG displayed at all times.
3. is cheap on parts.
4. is adjustable to different vehicles.
Other computable items from injector pulse and speed sensor:
RPM
MPH
Gallons
Distance
Acceleration
Decceleration
Hours
"I kicked a giant mouse in the butt! Do I have to draw you a diagram?"
Old 03-17-2008, 03:41 PM   #24 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I can't help much, other than my moral support, and pledge to buy one for my supra once it gets going.
Once feature that my bike has, that my SGII lacks is Cadance, might be cool for MPG computer . . .. . . Just an Idea.
Old 03-17-2008, 10:24 PM   #25 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
It seems that the arduino uses an atmega168 microcontroller w/ a bootloader, so it is programmed directly via serial/usb. I think other IC's (PIC, BASIC Stamp, etc.) require a board to interface with a computer via serial. Really old stuff (EPROM) requires data to be erased by UV and then loaded. Thank goodness it's not 1984...
Since I also have no experience I won't advocate the tough path anymore. It just seemed like the logical path if the experience can be found in this board. Essentially, the end product would be MegaSquirt-esque: purchase components, solder, download code, install, done...
If the arduino path is taken, another option is the freeduino: completely open source + USB. ~$24
Info for getting an LCD up and running. Apparently, to have buttons, input pins available, and run an LCD it needs to operate in 4-bit mode. Here's what I've found so far.
Reasoning
LCD interface in 8-bit
LCD interface in 4-bit
Source of LCD's (w/ or w/o backlighting) ~$15-20
This is kind of dumb, but what about an "analog" fuel economy gauge?
- LostCause
Old 03-17-2008, 10:40 PM   #26 (permalink)
Good link. Anything with "free" in the name must be good!
I just ordered one.
Old 03-17-2008, 10:51 PM   #27 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Isn't RPM the same thing?
Challenge me, or correct me, but don't ask me to die quietly.
Old 03-17-2008, 11:16 PM   #28 (permalink)
Liberti
LostCause's Avatar
I know you can buy, from SAE, the book on the OBDII protocols and how to interface - probably something necessary if you want to plug into the diagnostics port and not tap a bunch of misc. wires.
1.
2. Bus positive Line of SAE-J1850
3.
4. Chassis ground
5. Signal ground
6. CAN high (ISO 15765-4 and SAE-J2234)
7. K line of ISO 9141-2 and ISO 14230-4
8.
9.
10. Bus negative Line of SAE-J1850
11.
12.
13.
14. CAN low (ISO 15765-4 and SAE-J2234)
15. L line of ISO 9141-2 and ISO 14230-4
16. Battery voltage
The assignment of unspecified pins is left to the vehicle manufacturer's discretion.
PID's for requesting information (i.e. water temp, TP, vehicle speed, etc.)
Now, how to use all that data...
- LostCause
Old 03-17-2008, 11:25 PM   #29 (permalink)
Liberti
LostCause's Avatar
I just ordered one.
Man that's fast... I think I might too, I like how this is rolling along quite quickly.
The internet is a cool place, like a mega-library.
Adding buttons
Tutorial List
- LostCause
Old 03-17-2008, 11:32 PM   #30 (permalink)
Oh, don't mistake my buying one for committing to the project!
That said, if several of us were to get the similar platforms and start investigating further, I could see how it could snowball into actual progress.
Re-reading the thread, I can see why the *duino may not be the perfect platform for this project for a couple of reasons. But I've been intrigued with them for a while, so I thought, might as well get one.
SuperMID - Fuel Economy Display SVOboy Instrumentation 10 10-08-2009 04:41 PM
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 11 05-08-2009 02:04 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 07:26 PM
What features on your ULTIMATE fuel economy instrumentation? MetroMPG Instrumentation 17 05-04-2008 11:16 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
