Old 08-02-2008, 02:04 AM   #11 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
A MPG computer for a carb bike or car would be tricky. I have stuck my wideband sensor in the exhaust of my bike to see how it was tuned from the factory and the tuning seems to be off in a few places. So assuming a 14.7: ratio is not going to work well for a lot of bikes.
It seems like a map sensor might give more information than a tps. A lot of bikes have a CV style carb and the airflow through them doesn't have that much to do with the throttle position a lot of the time. If there is a big vacuum diaphragm on the top of the carb it is a CV(constant velocity) carb and measuring the slider position would be a lot more accurate than throttle. You prob have a CV carb since you are only getting 5 inches vacuum all the time. That is typically how they work. You can change the vacuum amount by adjusting the spring pressure on the diaphragm or drilling out/filling in the vent holes.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 08-02-2008, 02:17 AM   #12 (permalink)
nut
Coyote X's Avatar
CVK40
how a cv carb works They are a pain to get performance out of but they are pretty good at mileage.
After thinking about it I think if there was a way to measure slider position that would relate really well to fuel flow for everything except wide open/idle. And for that A good guess would probably be close enough.
Old 08-02-2008, 06:22 AM   #13 (permalink)
Certified Freak
Greenblazer's Avatar
Greenblazer's Taco - '07 Tacoma PreRunner Double Cab SR5 V6 4.0Liter
90 day: 24.54 mpg (US)
I have a motorcycle: 2002 Suzuki DRZ 400 K (K is for kickstart other models have Electric start) It is a Dirt bike that I modded to be street legal(Arizona allows this).
It gets around 50MPG, but the cost of maintenence offsets much of the money saved on gas. I have been daydreaming about making a 3 wheeled aero bike powered by a small motorcycle engine.
I would welcome a Motorcycle forum.
Later,
Allan Greenblazer
Old 08-02-2008, 08:44 AM   #14 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
yep, a motorcycle forum would have to cover all these aero-trikes we are all dreaming about.
A motorcycle forum might also be another thing to ATTRACT people to this site as well.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 08-02-2008, 09:55 AM   #15 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
OK - motorcycle/scooter forum made. I've had a quick go through and moved relevant threads over; if you see any I missed in your travels around EM, let me know.
Old 09-07-2008, 06:28 PM   #16 (permalink)
Red Beast - '82 V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Neon SXT
90 day: 28.71 mpg (US)
Besides a windscreen, what other mods are considered for motorcycles?
I have a Vetter fairing on the front, and am working on keeping speed down to the speed limit (Made a big difference already, 45mpg vs 38mpg) and learning to keep by knees in. I will try it without the trunk in a week or so when I have a new baseline from keeping the speed down. I have tried Power off coasting, but as mentioned earlier, you tend to shed speed too quickly, it does work well downhill (cutting the rpm in third has got to mean something right?)
One mod I am considering is a fabric "Sock" running from the fairing on each side to the rear of the bike, I would place my legs inside the sock and I think this will lower the CD over the lower body. Any thoughts on this?
Old 09-08-2008, 10:08 AM   #17 (permalink)
bennelson's Avatar
S10 - '95 S10
Have you every seen one of these before?
:::Mueller Windwrap XT Fairing and Body Sock :: January 2006 :::
It is a stretchy fabric used by rebumbent bicyclist to improve aerodynamics.
Seems like the same idea would work great with a scooter or motorcycle.
My YouTube Videos
Old 09-08-2008, 05:19 PM   #18 (permalink)
Contour - '98 Contour SE
90 day: 33.79 mpg (US)
Ninja - '99 Ninja 500R
90 day: 63.1 mpg (US)
Woo hoo, finally found others thinking the same things I am...
I have a 99 ninja 500. I have been trying to coax the most miles posible out of it. So far I haven't done a lot but work on driving skills (and tucking). I have been able to average about 63mpg out of it over the last few tanks.
I tried pulling the lower fairing off due to recommendations that the scoop on the front did more harm than the sides did good. I saw no noticable difference from that and put it back on last night.
I have switched to synthetic oil and have no front turn signals (due to damage before I bought it). I also have a broken front fairing, which makes me want to improve it with something better. I am very seriously looking into a "dustbin" style fairing. I am not a huge fan of how they looked on older bikes, but my photoshop of what mine could look like isn't as bad as I thought.
It isn't all that expensive ($575 + shipping new) and if it would fit it should make a big difference. If I could break the 100mpg mark with something like this I would be happy, and I think the potential is definately there.
I also want to regear as I have plenty of power and wouldn't mind bringing the RPMs down a little at highways speeds (where most of my commute is).
Does anyone know someone who has tried this (other than vetter)?
-Mr_C
Old 09-08-2008, 05:32 PM   #19 (permalink)
It was that type of thing that gave me the idea. I read somewhere about trailing fairings (on the trailing edge) make more difference than leading fairing. So maybe just an oversized shirt stretched over the trunk?
Old 09-08-2008, 05:43 PM   #20 (permalink)
bennelson's Avatar
S10 - '95 S10
I love the photoshop job of your cycle with the "dustbin" fairing on it.
I think one of those combined with some sort of "tailsock" would have to be a good improvement in aero.
I would like to do some more work on my cycle, but not until I finish the electric car conversion.
My YouTube Videos
Electric Motorcycle conversion bennelson Fossil Fuel Free 276 01-27-2012 11:24 AM
Instructables: 96V electric motorcycle bennelson Fossil Fuel Free 1 06-27-2008 01:51 AM
Help me with DIY motorcycle fairing bennelson Aerodynamics 10 06-06-2008 02:14 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 06:23 PM
Motorcycle fuel economy champ's advice for efficient cross-country touring... MetroMPG Motorcycles / Scooters 6 01-31-2008 02:38 AM
