Old 05-26-2010, 11:33 PM   #21 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by diesel_john View Post
I have a digital A/F meter that shows me the magic 14.7 number. I got it because I wanted to "see" what an EFIE (02 sensor signal modifier) would do. But, when the EFIE is off, the A/F ratio is pretty much bouncing above and below 14.7, so it's not doing much, just like you said.
CarloSW2
How does this EFIE work? What does the circuit look like? I once played around with the O2 voltage by just adding 0.2 of a volt to the signal with a 3v battery and a simple $5 voltage divider circuit and it gave me a mile per gallon or more. Did not check the placebo effect. Newer ECU's are harder to fool.
diesel
I have considered rigging up a little circuit to do this very thing. I was a little concerned about the A/F ratio when I did this, however. As I understand things, going a little more lean should not be a problem... This method would beat spending $75 for a EFIE gizmo.
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
DIY - Water Injection Stormin' Norman DIY / How-to 45 02-05-2009 04:42 AM
DIY - Ambient Air Fridge NoCO2 Saving@Home 13 05-10-2008 09:18 AM
DIY Needed - adjusting parking brake pull Yaristock DIY / How-to 22 04-17-2008 09:51 AM
DIY Solar charged electric scooter MetroMPG Fossil Fuel Free 4 01-09-2008 11:27 PM
