Old 03-02-2010, 01:39 PM   #21 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 66.4 mpg (US)
Here are few fuel economy related finnish test:
http://www.motiva.fi/files/1027/2006..._eng_final.pdf
oil test section begins from page 46
http://www.motiva.fi/files/950/annua...ng_07-rev1.pdf
begins from page 30-
http://www.motiva.fi/files/948/annua..._-2007_eng.pdf
Old 03-03-2010, 06:23 AM   #22 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Due to less relative wind resistance and less relative weight typically carried (relative to engine HP?)...I think personal vehicles are more sensitive to engine/driveline lube viscosities and lubricity? Maybe by a factor of 2 or 3? Just a guess....
Anecdotal stuff....
Preparing my Saturn SC2 for the "Switch"? - Bob Is The Oil Guy
Two days in, and I'm already noticing improved cold starts (don't have to hold down the key to get it to catch like I did with GTX on really cold days), and my gas mileage is up about 4.5 MPGs. 6 qts. Mobil 1 0W-30 K&N Oil Filter CHANGED FROM Castrol GTX High Mileage 5W-30
Tercel4WD.com • View topic - Slippery Slope
"So just before we took the Tercel on the 2,500 mile trek, I changed the tranaxel and rear differential over from 89-90 gear lube to Mobile 1 synthetic. First drained the units, cleaned the magnetic plug ends and flushed/cleaned with cheap ATF then drained and filled with the synthetic.
Now I had no way of comparing the improvements to mileage or much of anything for that matter until I did my coasting route down Academy Boulevard. Normally the stop light catches me a Wyoming so when I get green I accelerate to 35 mph and put him in neutral. I have a mile of downhill that only has 1 stop light that I usually cruise through. Now with the 80-90 gear lube, the Tercel would slowly gain speed and top out about 42-45 mph, just the speed limit. This would be the case in summer and in winter with the gear lube viscosity restriction, he would get to 38-39 on this stretch coasting.
Lo and behold, Now he zips right past 45 mph and I actually have to feather the brakes to stay under the speed limit. I know this is not very scientific. I don't care."
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 7 09-01-2009 02:44 PM
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 11:51 AM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
MetroMPG.com mailbag: details of 104 mpg fill-up? MetroMPG Hypermiling / EcoDriver's Ed 0 02-18-2008 10:31 AM
