Old 02-10-2010, 08:19 AM   #1 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 32.27 mpg (US)
Any testing on mpg effects of using various gear oils?
* regular dino gear oil
* full synthetic (same viscosity)
* synth ATF with added Lubegard or Militec or moly additive
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Old 02-10-2010, 07:39 PM   #2 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Accord LX
90 day: 35.57 mpg (US)
i saw a 3mpg increase at 72mph on my first tank. (over 11% increase)..
with the blizzard, i can reliably get another reading this week.
maybe next week or so.
full synthetic engine oil and full syth trans fluid, same velocity for my accord
single person car thread
Old 02-10-2010, 08:30 PM   #3 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
You can start here. Some good stuff in there.
"Judge a person by their questions rather than their answers."
Old 02-10-2010, 11:09 PM   #4 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
In theory, you shouldn't see a gain from using synth over conventional in the same viscosity.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 02-10-2010, 11:12 PM   #5 (permalink)
epic stock master
luvit's Avatar
i should double check the oil that was put in my engine.. the oil change place looked-up my car to choose the syth oil
Old 02-11-2010, 07:56 AM   #6 (permalink)
As far as I know...viscosity is more controlled with synth vs dino gear oil...meaning that when cold synth is thinner. One person claimed that after changing to synth gear oil...same weight...he could coast further with synth oil.
I had an '86 Escort that used ATF in a manual transaxle....thinking that using synth ATF with a good additive might work...but might be risky too.
Old 02-11-2010, 08:31 AM   #7 (permalink)
Good link!
Old 02-11-2010, 02:02 PM   #8 (permalink)
Ford recommends the use of Mercon-based fluid in almost all their manual transmissions, with few exceptions, that I'm aware of. You're correct thinking that synthetic, as a rule, is more stable. I'm not sure this applies in a transmission as much as in an engine, but I can't really support that thought.
Using synth ATF that applies to the same specs as your original trans fluid will be fine on it's own. You can go to Ford dealer and get a 4oz can of friction modifier, but it's probably not necessary for the older trans?
Old 02-11-2010, 04:58 PM   #9 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
If you search bwilson4web's posts, you will also find documented testing showing the effect of changing gear oil type/viscosity in his gen. 1 Prius.
Old 02-11-2010, 05:05 PM   #10 (permalink)
The viscosity stability of synthetic gear oils should return better efficiency in cold conditions. It's an issue for transmissions/differentials, since they don't benefit as much from the heat of combustion as engine oil does.
I can find dozens of links that claim to support this notion.... but can I find one on short notice that appears to have some science behind it? Nope!
Anyone?
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 08:03 AM
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 7 09-01-2009 03:44 PM
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 12:51 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 10:15 PM
MetroMPG.com mailbag: details of 104 mpg fill-up? MetroMPG Hypermiling / EcoDriver's Ed 0 02-18-2008 11:31 AM
