Old 06-30-2017, 10:04 PM   #1 (permalink)
2011 Honda Civic LX
Honda - '11 Honda Civic LX
90 day: 28.85 mpg (US)
Fit - '17 Honda Fit LX
2017 Honda Fit - Kammback spoiler?
I'm the proud owner of a new 2017 Honda Fit. I was interested in finding a Kammback type of spoiler that I could use to replace the stock little duckbill the car comes with. Anyone know if one is being made, or potential fuel savings?
Old 07-01-2017, 12:21 PM   #2 (permalink)
Yes, http://www.motortrend.com/cars/honda...v-first-drive/. But the mileage gain is obfuscated by the EV conversion.
Ecomodder member bottsapper posted this in 2010:
Followed by aerohead's analysis a few posts later.
I hadn't thought about this before. It took about 10 minutes to learn the above. When I was closing tabs, I found this:
https://www.lelong.com.my/honda-jazz-03-08-spoiler-oem-mugen-mugen-pro-fit-kenstyle-fiber-lklailai-I1827658B-2007-01-Sale-I.htm
California98Civic (07-01-2017), Daox (07-03-2017)
Old 07-01-2017, 01:20 PM   #3 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Undoubtedly #4 in this image is likely the best for drag reduction purposes. Remember to compare your choice to an overlay of "the template" on your fit. What is that? Something like this:
http://ecomodder.com/forum/showthrea...tml#post373881
Search this site for much more, if you have not already.
I hope that helps.
Old 07-01-2017, 08:30 PM   #4 (permalink)
2011 Honda Civic LX
It does help a bit. The only issue I'm running into at the moment is the Fit EV is the previous generation/body style, rather than the new one I'm running. Otherwise I would snag a bunch of EV aerodynamic parts and bolt them up.
Old 07-01-2017, 08:52 PM   #5 (permalink)
Cyborg ECU
Yeah. I was wondering that. The trail end shape changed quite a bit. No doubt these do not "fit" (pun). But I assume there are versions for the new gen too. Look around. Post your research.
Old 07-02-2017, 01:06 AM   #6 (permalink)
I'm faced with the same 'opportunity' on my lift-back (sort of an elongated hatch) body; the part has never existed. I have a sheet of textured aluminum about 3x4ft. I may use that if I can find a way to wire-wrap the edge. I also like the idea of making it in perforated sheet metal.
The other half of your question... potential fuel savings? On a less aerodynamic car you might see 1 or 2 mpg. On a high mpg car, less.
You want more — because there is more. The Morelli fluid tail:
http://ecomodder.com/forum/showthrea...info-2072.html
