Old 06-22-2014, 03:20 PM   #1 (permalink)
...beats walking...
Anybody read Finnish?
• Research paper (notive the NUVA 6. item pictured on page 15):
https://publications.theseus.fi/bits...pdf?sequence=1
The Following User Says Thank You to gone-ot For This Useful Post:
aerohead (06-23-2014)
Old 06-22-2014, 03:25 PM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Translate PDF Files and Office Documents
There has been a recent change: Google Translate can now be used to translate PDF files and Microsoft Office documents. Google first converts the document to the HTML format and then it displays the translated HTML file.
The nice thing is that Google converts the documents on the fly even if they haven't been indexed by Google. Just paste the address of a document in Google Translate's text area and wait until the translation shows up.
I just tried google translate, it said the file was to large , apparently it will only translate files 9 pages and under.
Save gas
The Following User Says Thank You to ecomodded For This Useful Post:
Old 06-23-2014, 05:50 PM   #3 (permalink)
Finnish
Don't know a word.
I skimmed through it quickly.Looks like he installed a ScanGauge,established a baseline for the vehicle on a fixed route,then went after some electric loads,lower viscosity lubes,lower rolling resistance tires,then modest aero mods,so as not to loose any 'normal' utility.And published the difference compared to the baseline.Cool!
Old 06-24-2014, 07:16 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Osa 1.= part 1=muutos 1
Kitkarenkaat=studdless winter tires
Umpinaiset pölykapselit= smooth hubcaps
LED huomiovalot =DRL ligths
Vararengas pois= remove spare tire
Rungottomat
pyyhkijänsulat= frameless windshield (aero)wipers
Vaihteistoöljyt= transmission oils
Termostaatti =new thermostat
Osa 2.=part 2=muutos 2
Takalasinpyyhin pois= removed rear wiper
Pyöränkulmat= wheel angliments adjusted/checked
Pohjamuovit= smooth undertray
Saumoja tiivistetty= filled some seams of the car
Ilmanottoaukkoja peitetty= some grill blocking
Osa. 2,5= part 2.5=muutos 2.5
Kesärenkaat= summer tires
Keula auki (lämpöongelmia)= opened some grill due to heat problems on summer
Osa 3.=part 3=muutos 3=lopussa
Moottorinilmansuodatin =new engine fresh air filter
Matalakitkaiset öljyt= low friction oils
Polttoainesuodatin= fuel filter
Öljytilan puhdistuskäsittely= engine oil flush tretment
Suuttimien puhdistuskäsittely= injector treatment
Moottorinalamuovi pois= removed belly pan
I think Antti is also here at ecomodder so he can tell more...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (06-24-2014)
