Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 04-09-2012, 11:08 AM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
anybody tried hydrogen generation?
before anybody jumps on this thread who hooked up a hydrogen generation kit and says it doesnt work, was the timing adjusted properly to take advantage of the fuel? hydrogen burns at a different rate than gasoline, the timing must be adjusted. Sort of like setting up timing on regular fuel and then running high octane fuel that burns slower, and combustion is not complete untill well after TDC.
I know we are yet to see some conclusive evidence of it working, but the math seems sold. optimum air-fuel ratio for a gasoline engine is 12:1, being 12 parts air to 1 part gasoline. at 30 mpg -let me carry on in metric, I find it easier, 30 mpg is 7.8L/100kms. Alright, if you drive one hour at highway speed, youc car getting 30MPG or 7.8L/100 you would have used 2 gallons or 7.8L of fuel. at 12:1 air fuel ratio that should be 24 gallons of air, or 93.6L of air consumed with that fuel. It does not seem right, that amount of air does not sound right, but you cannot dispute the logic.
hydrogen, while I hear only has about half the energy of gasoline, has a perfect air fuel ratio of 2:1. do if the engine needed 48 gallons of air fuel mixture still only 24 gallons would need to be generated, or about 47L of hydrogen gas.
so how much energy would it take to generate that much hydrogen, while installing a second alternator to help increase the electrical demand would also decrease fuel economy the cost of free water would negate the increase in fuel economy, no?
Old 04-09-2012, 11:24 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Moved thread to the unicorn corral.
I will happily move the discussion elsewhere if we get that pesky "evidence" issue sorted out.
Also: this topic been discussed plenty here in the forum. You could spend hours reading.
The search tool on the top left of the page uses Google (familiar syntax) for user-friendliness. If you click the Advanced search link, you can use different search options & syntax via the forum's built-in search feature.)
Old 04-09-2012, 12:06 PM   #3 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
You've confused mass ratios with volume ratios, hence your absurd results.
The Following User Says Thank You to jakobnev For This Useful Post:
Frank Lee (04-09-2012)
Old 04-09-2012, 12:17 PM   #4 (permalink)
EcoModding Lurcher
mort's Avatar
Yes, there are a couple of posts here on ecomodder that refer to this paper from 1977!
Hint:
Ideal A:F is closer to 14.7:1 and is mass. So 7.8 liters is 5.6 kg of gasoline (0.719 kg/l)
5.6 * 14.7 = 82.4 kg of air. Air weighs about 1.2g/l that's about 70,000 Liters of air... If the A:F for H2 is 2:1 you'd need 40 kg of H2 at 0.089 g/l that's about 449,438 liters. You might want to check your assumptions.
-mort
Old 04-09-2012, 06:45 PM   #5 (permalink)
Wow. Just wow. The math has been gone over time and time again re: hydrogen produced vs hydrogen needed and also energy needed to get the hydrogen. "Timing" isn't the deal killer for this albatross.
Old 04-09-2012, 09:52 PM   #6 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
cost of running a generator to produce electricity is 5 times that of electricity from a wall outlet and my figures to produce enough hydrogen to replace a gallon of gasoline, figuring that it takes 240 watts to produce a liter of hydrogen and that it takes 1352 liters or hydrogen to equal a gallon of gasoline and my electrical costs are $0.12 per KWH it would cost me $37.30 at home to produce enough hydrogen to replace a gallon of gasoline, or it would cost $186.50 if I was using my cars alternator to power a hydrogen generator, I've made hydrogen at home and I've made hydrogen using a small industrial fuel cell hydrogen generator and those figures look pretty accurate, that is why if you buy a bottle of hydrogen from a welding supply shop, it's extracted from natural gas, extracting it from water costs to much!
The Following User Says Thank You to Ryland For This Useful Post:
ChazInMT (04-25-2012)
Old 04-10-2012, 03:19 PM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Oh, of course! In well over 40-odd years of various people tinkering with hydrogen for internal combustion engines, nobody at all had thought about messing with ignition timing! That is, up to now! You've stumbled onto the correct answer! OMG! Surely you're going to win the next Nobel prize in chemistry because of this!
</sarcasm>
Old 04-10-2012, 04:35 PM   #8 (permalink)
Originally Posted by Ryland View Post
it would cost $37.30 at home to produce enough hydrogen to replace a gallon of gasoline, or it would cost $186.50 if I was using my cars alternator to power a hydrogen generator ..... that is why if you buy a bottle of hydrogen from a welding supply shop, it's extracted from natural gas, extracting it from water costs to much!
This is what I have been saying since 2005. Your numbers are very, very close to what I came up with.
Ryland (04-10-2012)
Old 04-11-2012, 10:41 AM   #9 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
There are people who claim to have things working, but they lie low. I know someone who is working on an "HHO" for his vehicle, but has a couple grand invested in the components and it still isn't operational. He has to get some fancy electronic equipment custom built (fuel control) along with a few other things. It seems to be turning into a perpetual "need this need that". BUT this guy has lots of $$$ to spend and is convinced that HHO is the way to go.
Personally, I would steer clear. By the time all the stuff is bought and installed, I could have bought 6 or 7 years worth of gas. And even then I might find that I'd get worse fuel mileage (who knows?). Not really the direction I am going, nor the investment/risk I'd want to take.
Old 04-12-2012, 12:28 AM   #10 (permalink)
The funny thing... with all the equipment, electronics, fluid storage, injection, etcetera... they buy, they could have already assembled and built a water injection system integrated with a piggyback ECU to lean out the fuel charge and they'd be saving gas, already.
Not that distilled water is free, but the numbers work out... somewhat.
