Old 08-03-2008, 06:08 PM   #11 (permalink)
EP3 - '03 Civic Si
90 day: 31.73 mpg (US)
Scooter - '93 Elite 80
90 day: 74.87 mpg (US)
Ape - '07 Sportcity 250ie
90 day: 66.97 mpg (US)
Originally Posted by steensn View Post
Slip Control (ABS) integration expert here. You ABS or ESC system will not work in accesory mode at all. If you key the car back into ignition without turning the car on the ABS module will turn back on. It should not activate at all, but you could have a faulty module, probably Advics or Bosch who's failsafing is jacked up. If you think it is doing it while the car is in acc then you are mistaking it for something else.
I'm not sure what manufacturer made the abs components on this car, guessing honda because they are still stock. I know it is the abs system because that is the only thing that feels like that on the brake pedal, it is like a turning gear is hitting the brake pedal and causing that very familiar vibration through it. I am wondering if it is the self check system as i believe on this car it does an abs self check a certain amount of time after the car is turned on, and if i turn it off and then back into the on position then it would theoretically reset the circuit and run another self check and perhaps i am braking sometimes when it is self checking? I mean the abs should be working when the ignition is in the on position correct? The eps does a reset and then works, the air bags work, the radio works, the speedo works, why would the abs and ebd be the only electrical systems not to function after the circuit is reset?
Old 08-03-2008, 07:56 PM   #12 (permalink)
silverfox's Avatar
In my opinion the simplest way to kill your engine without having everything reset would be to "kill" the coil - i would find the power wire going to the coil and put a normally closed relay in that line - run a small switch to activate the relay to put an open in the circuit - this only kills the spark - everything else works the same (if you want to restart the engine just release the relay and you would have spark again- if the engine were turning <vbg>)
Old 08-03-2008, 08:41 PM   #13 (permalink)
Silver EP3 - '02 Civic Si
I have 4 coils, but I checked my schematic, and they all have a common ground. that may be the easiest thing to do it cut the ground...
Old 08-03-2008, 09:59 PM   #14 (permalink)
silverfox's Avatar
That should work - anything to break the power circuit to the coils (if you power the relay from an ign hot wire and have it latch open with a push button the relay would go back to it's n\c position when you turn the key off) be kind of nice to have a push button that would kill the engine but reset it's self when you turn off the key so all you have to do is start the motor normally
Old 08-04-2008, 09:22 AM   #15 (permalink)
The Hulk - '96 Aspire Base
90 day: 51.64 mpg (US)
Black Hole - '06 Rio LX
90 day: 39.16 mpg (US)
Send a message via AIM to steensn
You are correct. If you feel a puslation in the brakes after you put it back into ignition then it is the self test mode that all slip control modules do when they get ignition power again. If it only happens after you turn the key back to ignition then you will get a pulsation of all coils (8 if it is ABS and 13 if it is brake TC/ESC) along with a running of the motor.
FYI, no vehicle manufacturer maks their own ABS or ESC units. They are all from Tier 1 suppliers that specialize in this unit. Cost and speciality are the main reason. I am not aware of any aftermarket replacements either, not really feasible but everything is possible with the right time and money.
2006 Kia Rio
1996 Ford Aspire
Just bought 92 Civic vx with bog problems jttriesch Off-Topic Tech 15 11-10-2010 02:47 PM
I cause more problems than I fix!!!!! bennelson Off-Topic Tech 11 06-09-2008 04:37 AM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
webpage problems Yaristock The Lounge 6 04-12-2008 11:08 PM
problems with EVs igo Fossil Fuel Free 26 01-16-2008 12:15 PM
