Old 11-01-2011, 10:56 PM   #1 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Anyone know how to fix oil burning?
My CRX Si has been burning alot of oil though the exhaust, like a quart every 4 days.... My mechanic said that it was the piston rings going bad... Is there anything I can do to fix it without rebuilds or swaps.... Like something under $100 haha
His nephew said I could try Lucus Oil additive that stops leaks or move up to 15w40 oil... What do you guys think?
Old 11-01-2011, 11:00 PM   #2 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
Auto-Rx Internal Engine Cleaner
Old 11-01-2011, 11:04 PM   #3 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
There are tests you can perform to see if the rings are your problem. PCV system, if plugged up could contribute to the problem, considerably in some cases.
Cylinder compression test.
Leak down test, then add some oil to see if the leakage is ring related.
regards
Mech
Old 11-01-2011, 11:05 PM   #4 (permalink)
You could try seafoam.
regards
Mech
Old 11-01-2011, 11:10 PM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
If it came on suddenly I'd suspect a bad valve stem seal or a broken piston ring. If it came on over time I'd suspect wear.
Old 11-01-2011, 11:15 PM   #6 (permalink)
redyaris - '07 Yaris
90 day: 47.98 mpg (US)
Gray - '07 GS500 F
Motorcycle
90 day: 70.4 mpg (US)
KLR - '07 KLR650
Last 3: 62.78 mpg (US)
Have a "leak down test" done first then deside on repairs needed
Old 11-01-2011, 11:25 PM   #7 (permalink)
The Neon - '00 Neon
House of Tudor
He also put my car on the lift and the oil pan was leaking I suppose at the gasket but he said it probably doesn't amount to even half of the leak/burn. The back of my car IS turning black so I'm pretty sure its coming out the exhaust. Let me Youtube the leak down test and see what it is and ill get back
Old 11-02-2011, 01:05 AM   #8 (permalink)
I just starting using Mobil 1 "High Mileage" 10w30. It's supposed to be better for cars with over 75000 miles. It's supposed to condition seals to help prevent leaks. A quart every 4 days sounds like more than just a leaky seal. Let us know what you find out.
Old 11-02-2011, 01:36 AM   #9 (permalink)
How's the compression? If it's low, then you are probably burning oil past the rings.
No real fix for that other than taking the engine apart and replacing the rings (and honing the cylinders, and replacing the bearings, and basically doing an engine rebuild).
-soD
Old 11-02-2011, 08:49 AM   #10 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
There is another possibility,
You may have carbon stuck rings.
Pull the spark plugs.
Rotate the engine so no pistons are at TDC
Using a funnel, fill the cylinders with kerosene
Let sit overnight.
Agitate the solution with a block of wood and hammer on the block.
Wiggle the crank a bit.
Refill low cylinders.
Let sit a few more hours.
Pump out kerosene.
Rotate crank, first by hand then by starter to blow kerosene out of bores.
Change oil, letting it drain real good.
Put a teaspoon of Marvel mystery oil in plug holes.
Replace plugs.
Drive for a day or two.
Change oil again.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
