Old 08-27-2009, 01:21 AM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Anyone know if there's an 1st gen Insight speed vs. MPG graph?
I'd be very surprised if someone hasn't done one, but with the gen 2 out, Googling Insight 1 stuff has become more problematic. I couldn't turn one up.
Anyone seen one?
SVOboy (08-27-2009)
Old 08-27-2009, 01:29 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Darin's doing my work for me
Old 08-27-2009, 02:28 AM   #3 (permalink)
The problem you might face is that the Insight is very inconsistent: small headwinds, almost imperceptable slopes, even changes in the pavement, and similar things can change mpg by as much as 50%. For instance, the trip in to my lab is about 17 miles, almost all freeway or 4-lane highway, with an elevation change of about 300 ft. On a warm day, I'll usually register 90+ mpg going in, but am lucky to get 65 mpg on the way back. I can see a gain in mpg just by driving with the wheels close to the lane markings, rather than in the center of the lane where wear has made the pavement rougher.
I think most of this is caused by the lean burn. When you're in the right load/temp/rpm/phase of moon range for it to kick in, you get much better mpg.
Old 08-27-2009, 02:38 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Do you have a monitor for lean burn? I know it'll be touchier than on my current VX engine, but if I can pull 65 even in a headwind I'll be happy (especially if the other way is 90 mpg!)
Old 08-27-2009, 12:30 PM   #5 (permalink)
Ah. Well my interest is in seeing baseline figures in as-controlled-as-possible conditions, such as I did with my dad's Corolla: Tested: speed vs MPG - 2006 Toyota Corolla automatic
- runs over a range of increasing speed on as flat a road as possible, in light winds, no traffic
- bi-directional averages
I realize it would only apply to flat road, no wind/traffic conditions, but it would at least give you an idea of what the car is capable of in ideal circumstances.
Old 08-27-2009, 02:38 PM   #6 (permalink)
The only monitor I have is the instantaneous mpg readout: if I'm driving along and suddenly it jumps from 65-70 to 90-120, I figure it switched into lean burn.
Old 08-27-2009, 02:42 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Good point. I forgot the cluster had instantaneous since I haven't installed mine yet
Old 11-25-2009, 10:56 PM   #8 (permalink)
discovery's Avatar
I read somewhere that the lean burn on insight can go up to 1:27 air:fuel regular car A/F is 1:14.7
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 11-28-2009, 12:09 AM   #9 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I don't know of any, and I've looked hard for one. I guess I'll have to make one.
Old 02-20-2010, 10:54 PM   #10 (permalink)
OurInsight - '06 Insight
I'm a bit late to respond, but over on CleanMPG the undisputed master of MPG is a guy named Sean, aka "RighLaneCruiser." His lifetime average MPG is above 90MPG. Anyone who can get those numbers over a lifetime must know something. When I asked him about the optimum cruising speed he told me that it was 36-37 MPH, 5th gear, lean burn, level road. I have since done some driving of my Insight in that range and I can confirm that the economy is pretty impressive under those conditions. On a recent trip to the area of Eunice, LA, absolutely flat rice growing country, I was getting 100-125 MPH on country roads, depending on .25 degree or less up/down grades and on road texture. It is only possible to pull around 80-85 mpg on the highway in the 50-55 MPH range. I realize that this anecdotal and not a carefully controlled experiment, which I think is impossible given the extreme sensitivity of the car.
BTW, lean burn is displayed on a ScanGauge with special programming of the X-gauge feature. Go to CleanMPG and search for "lean burn" and "X-gauge." Several folks have listed the code, but I don't have it handy. As someone else noted, it is also detectable by the sudden jump in the fuel consumption display to numbers greater than 75 MPG(assuming engine warmup).
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
Honda Ridgeline MPG vs speed graph: fuel economy with & without cargo trailer MetroMPG General Efficiency Discussion 22 08-18-2011 03:36 PM
Tested: speed vs. MPG, 2008 Corvette Z06 (505 hp) MetroMPG General Efficiency Discussion 66 02-09-2010 11:14 PM
mpg vs. speed - Metro graph MetroMPG Hypermiling / EcoDriver's Ed 26 06-05-2008 04:45 PM
