Old 09-02-2008, 04:00 PM   #1 (permalink)
Is Anyone Using a Fuse?
I tried to be very careful when soldering everything together, but has anyone put a fuse on the 12V feed to their unit in case of a short?
Old 09-02-2008, 07:25 PM   #2 (permalink)
Bun - '02 Focus ZTS
90 day: 31.3 mpg (US)
I power my unit from a cigarette lighter cord with a built-in fuse.
I recommend that everyone have a fuse or other protective device on the power wire to the guino.
I think it's also important to protect against wiring shorts. I put 10k resistors on my signal wires to protect the vehicle's wiring against shorts caused by me.
Old 09-02-2008, 09:15 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Mine is connected to the courtesy circuit that is already protected by a 20A fuse.
But I wonder what would be the proper size fuse to use on the guino. Something smaller I would imagine.
Winter daily driver, parked most days right now
Summer daily driver
Old 09-02-2008, 10:08 PM   #4 (permalink)
I was told that it operates at .5 amps and that my 26 gauge wire is rated up to 2 amps. So I intend to put a 1 amp fuse ahead of my power.
Old 09-02-2008, 10:14 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
The fuse protects the wiring, not the component. As axaday found out, he was fortunate to already be on a fuse protected circuit, so a fuse there would have probably been redundant (depending on the gauge of his hookup wire).
There is really no end to the ways to build it incorrectly and you cannot defend against them all. Adding a transistor can go wrong, so adding a fuse is not a zero risk operation. The safest bet is to take your time and try and build it correctly, and take tons of continuity readings to make sure things are connected where they should be and not where they aren't, or at least make sure your injector/vss leads have at least 100kohms between them and ground/positive, and that there isn't a dead short from positive to ground anywhere before or after the regulator.
Actually, those might be a good couple "sanity checks" with an ohmeter that could be made into a wiki page that should improve your odds of not totally messing something up.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Kill switch how-to bbjsw10 DIY / How-to 162 03-31-2012 06:49 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
DIY - Hardwired iPod SVOboy DIY / How-to 0 11-18-2007 03:23 AM
