Old 09-23-2009, 02:42 PM   #41 (permalink)
vw diesel , 2004
Their compatibility chart suggests that the scangauge would correctly report my FE on my '04 diesel jetta vw.
Could anybody confirm that?
Since I burn biodiesel 90% of the time, I have no good way to evaluate fuel economy even at fill ups.
Thanks,
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
Old 09-23-2009, 03:14 PM   #42 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
Unfortunately, no. The scangauge uses air flow and calculates fuel usage from that. If the car runs on a different fuel/air ratio, or like yours, a variable ratio, it will be incorrect. The problem is that the actual fuel injector information is not an OBD-II spec data point, so none of the carmakers report it.
Can you not measure the Bio as you fill it?
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 09-23-2009, 04:45 PM   #43 (permalink)
Ryanrpm's Avatar
Ryanrpm's Tundra - '05 Tundra Limited, Double Cab, 4x4
90 day: 17.59 mpg (US)
1993 Civic EX 1.6L - '93 Civic EX
90 day: 49.61 mpg (US)
Originally Posted by Christ View Post
You probably get this a lot.......but why did you choose your username to be "Christ"?
1993 Honda Civic EX - Latest Hwy mileage: 45 mpg.
Current mods: Ozone extraction from Distributor cap. O2 sensor wrap. Mudflap reversal. Wiper delete. Side mirrors delete. A/C delete.
Old 09-23-2009, 04:55 PM   #44 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by easy View Post
Christ,
This is from the scanguageII compatibility list:
1997 WORKS ON ALL EXCEPT: Ford, GM and Dodge trucks with diesel engines.
Ford Explorer and Ranger - No Speed, Distance or Fuel Economy information (MPH, MPG, Miles driven).
1998 WORKS ON ALL VEHICLES EXCEPT: Ford Explorer and Ranger - No Speed, Distance or Fuel Economy information (MPH, MPG, Miles driven).
Oh yeah, mechanical components... mibad - I forgot Ford was behind the times at that point.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 09-23-2009, 04:56 PM   #45 (permalink)
It's my real name, minus a few characters. Chris is entirely too common, although it revels the same pronunciation as Christ, when you silence the T, as most do.
The way my name is pronounced leaves the I as a short vowel instead of an enunciated long vowel. In other words, it's Chris with a "t" sound at the end. Christ. (The T sound mimics the sound at the end of words like "At", "Eat", "Bat".)
I'm agnostic - it has nothing to do with religion.
Old 09-23-2009, 06:29 PM   #46 (permalink)
"Can you not measure the Bio as you fill it?"
Not accurately. Cheapo flow meters often are inaccurate at low flow rates like I would have. Also, biodiesel damages a number of common polymers and would likely eat a cheap flow meter in a week. Gas cans hold approximately five gallons, but how do you estimate that last half can? I have a volumetric flask, but filling the tank one liter at a time would be, ahhhh, tedious to say the least.
I'm open to suggestions if I have overlooked an accurate and inexpensive and elegant solution to measuring my fill ups.
Finest regards,
troy
ps, Oh yeah, I cook my own biodiesel, so this is not from a commercial station with a certified pump/meter.
tr
Old 09-23-2009, 06:49 PM   #47 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by dtpmike View Post
I put that JC Whitney coupon in and shipping was not free. $127.99 then $20 shipping. There is another code to enter in order to get free shipping, but it only allows one code per order.
The JC Whitney thing should be posted as a sticky.
Anyway DO NOT USE OLD CODES, you need to search on google for the current 20% off and free shipping code IT DOES CHANGE but is always posted somewhere on the internet, remember that it DOES NOT RUN EVERY MONTH BUT ABOUT EVERY OTHER MONTH, be patient and JC Whitney will deliver,
Save yourself money and take 5 minutes to look up the current codes, occasionally they have even beter coupons, also remember that free shipping is only on specific shipping methods, you pay for speed and if the special isn't running this month, wait till next month and it will.
Also free shipping is not to Canadia or anywhere but the lower 48.
Cheers
Ryan
Old 09-23-2009, 09:16 PM   #48 (permalink)
Ryanrpm's Avatar
Today...JC has it for $159......
Thought it was $149...
Old 09-26-2009, 03:20 PM   #49 (permalink)
rmay635703's Avatar
What is $159 - $31.80 of coupons?
Old 09-26-2009, 03:22 PM   #50 (permalink)
Make sure the coupon has free shipping.. or else it is $19.99 extra
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 03:36 PM
ScanGauge Canada DavidH Instrumentation 4 08-16-2010 05:07 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 04:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 02:09 PM
