06-05-2010, 10:26 PM
#61 (permalink)
Looking for a new way
ScanGauge on '00 Dodge 2500 V10?
Does anyone know of any reason that the ScanGauge would not work on a 2000 Dodge Ram 2500 with gas V10 engine? Can it handle 10 cylinders?
Thanks!
The Silver Sipper:
The Black Beast:
Dodge Ram 2500, Gasoline V10, 4X4, Auto
Best MPG recently was 9.8 since improving driving habits; 8.3 before that.
Resigned to hauling only, now that I secured the Prius.
06-07-2010, 11:16 AM
#62 (permalink)
ScanGaugeII - Compatible Vehicle List
Looks fine. The dodge Diesels have problems, but a gasser should be fine. (according to the list, of course)
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
The Following User Says Thank You to PaleMelanesian For This Useful Post:
03-03-2011, 09:41 PM
#63 (permalink)
Anybody know how the ultraguage works vs. the scanguage?
08-16-2011, 04:39 AM
#64 (permalink)
Is there any difference, other then pricing, in the Scan Guage II from ecomodder compared to Linear LOgic, such as newer software or technological updates???
I noticed that Linear Logic says it has Performance Monitor, XGuage, 15 built in guages(compared to 12 on EcoModder) and 4 trip meters?
Do both have the exact same gadgets built in? If not, then I see no reason for paying an extra $20 from LL.
Thanks everyone!
08-16-2011, 09:32 AM
#65 (permalink)
I got a SCII over 5 years ago, and ended up selling it to a friend about 2 years later for $60. I got to the point where it wouldn't tell me anything I didn't already know, and got bored with it. I think it might be nice to be able to test out some more advanced techniques without having to do them on the whole tank, so I just picked up a UltraGauge.
It should be here in a few days, will I miss anything from the SCII with very early firmware?
08-16-2011, 05:16 PM
#66 (permalink)
...beats walking...
...the current ScanGaugeII (SGII) models have the newest revision 4.05 firmware, how old was your SGII?
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
08-16-2011, 05:18 PM
#67 (permalink)
If you send your old SGII into linear logic they'll update the firmware for a minimal fee.
10-10-2011, 06:07 PM
#69 (permalink)
My SGII had firmware 3.0 on it.
I've been using the Ultraguage for a while now, and its superior in MOST ways, except nothing ever really resets? It looks like the model that came out a week after I got mine, now has trip gauges that reset every time you start the car. When I fill the tank, the 'trip MPG' or 'AVG MPG' never resets. None of the gauges really appear to reset unless you go and manually reset them.
However, the Ultraguage reads my vehicles fuel cut as 999 MPG, and it shows an extra number to the right of the decimal on most gauges. For things like inst. GPH, this is key. The SGII said 0.3 GPH at idle, whereas the UG says 0.26, a much more useful number. It sure is harder to set up, and a bit less user friendly to use, but 6 gauges at the same time are great.
If my UG had trip gauges that reset, I would have no complaints. I might have to send it in to get it updated, it just sounds like a hassle. I still didn't go through a full tank on the UG, so id like to get it calibrated before I send it off mid-tank.
10-11-2011, 09:22 AM
#70 (permalink)
If you upgrade the SG, it'll have those features as well - 2 decimals on GPH and accurate reading of DFCO.
