Old 06-10-2011, 03:03 AM   #91 (permalink)
texanidiot25's Avatar
Formula - '96 Formula/Trans-Am
90 day: 19.31 mpg (US)
I think he's talking about something that actuates in response to coolant temps, using a spring. Not unlike how the engine's thermostat is simply a spring that opens by expanding at a certain temp.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 06-14-2011, 08:18 AM   #92 (permalink)
wwkayaker's Avatar
Kayak hauler - '05 Lancer ES
90 day: 35.4 mpg (US)
Originally Posted by khafra View Post
I know there has to be a simply engineered solution I'm missing, but how do you get a spring-loaded flap to open under low pressure and close under high pressure?
Put the spring to where it is pushing back towards the car on the top side with the bottom side being the part that swings against the air movement. I will try to draw it for you but I only have the basic keyboard functions so bare with me.
..........spring=/
................../o=fulcrum
incoming air=/ =radiator side of air dam
The springs could be mounted on the ends of the air dam and be attached by some metal to the fulcrum. Be sure to reinforce the entire thing to prevent any bending under the pressure. You will have to test different springs to find the right one that will be open at less than the speed at which you want it to be fully open. Also, the spring side of the lever will have to be covered to prevent the air pressure from pushing on it unless the entire air dam is on the incoming air side of the lever.
The Following User Says Thank You to wwkayaker For This Useful Post:
khafra (06-14-2011)
Old 06-16-2011, 10:25 PM   #93 (permalink)
when might we get an actual picture of this adjustable grill block? I'm thinking were all picturing one for ourselves, so it be nice to see one for real.
Your only as good as your last mistake
grill block
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
