Old 01-01-2013, 01:23 PM   #141 (permalink)
90 day: 39.62 mpg (US)
90 day: 41.56 mpg (US)
I checked today, bent the pushrod around a bunch and the JB weld seems to be holding quite well. Better than I expected for sure. Now to get it hooked up to the actuator...
Current project: Heating the manual trans with engine coolant
Old 01-01-2013, 08:12 PM   #142 (permalink)
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
I worked on the grill block again last night. Its really starting to get near to its end form.
Here is a shot of the actual pushrods I used. I picked them up at a local hobby store. They're made for radio control airplanes. By the time I had sanded mine down those ridges were completely gone on the grey pieces. I only sanded it down in the area of the bend.
Hey Daox, speaking as a model airplane modeller I wanted to make a quick mention about the pushrods you chose. They are known for expanding and contracting with temperature changes and can mess with the trim settings on your model. Your use of such a short run should minimize this tendency though. Great project!
The Following User Says Thank You to pletby For This Useful Post:
Daox (02-08-2014)
Old 01-08-2013, 06:52 AM   #143 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Hi Daox, any news? Any tests? Photos?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 01-08-2013, 08:59 AM   #144 (permalink)
None yet. Its in the plans, but just haven't had time for it quite yet.
Old 01-08-2013, 09:08 AM   #145 (permalink)
AndrzejM's Avatar
So I'll still keep my fingers crossed
Old 01-09-2013, 02:01 PM   #146 (permalink)
Very nice work!
Old 01-09-2013, 02:06 PM   #147 (permalink)
Thalmaturge
Eeyore - '04 Honda Civic Hybrid
Go Pod - '00 Honda Insight AC
The Tinyvan - '07 Honda Fit Sport
A simpler version for those of us with mechanical knowhow but no computer knowledge would be this:
German Supply - Parts for VolkswagenŽ Cars - Home
Originally used with a pushrod or control cable and vent flaps in air-cooled VWs, available for opening at 65-70C or 85-90C.
Sam
The Following 6 Users Say Thank You to samwichse For This Useful Post:
aerohead (01-09-2013), AndrzejM (01-10-2013), ausias (03-15-2013), Piwoslaw (01-10-2013), pquijal (01-10-2013), Vekke (01-25-2013)
Old 01-09-2013, 09:46 PM   #148 (permalink)
V8 guy
I don't know how this didnt make it on the wiki before, but its on there now.
Grill block partial or full - EcoModder
Old 01-10-2013, 11:30 AM   #149 (permalink)
starting with a brick
subscribed with a soda.
Old 01-21-2013, 12:38 PM   #150 (permalink)
Simtronic
Send a message via MSN to Simtronic
Great idea, very similar to mine, I was going down the simple route of no electronics just a heating thermostat bolted to radiator operating central locking actuator when the temperature exceeds 80 degrees just those two components and a fused supply from ignition on circuit. I guess I should also wire a manual override switch in the unlikely event of the thermostat failing
actuated, ardunio, automatic, grill block
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 10:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 06:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 05:36 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
