Old 07-26-2011, 10:58 PM   #1 (permalink)
Question Is Arduino Nano compatible?
Hi,
I was wondering if I can use an Arduino Nano 3.0 board with OBDuino32K.
Can I? Will it make any difference in programming, etc?
Cheers
Old 07-27-2011, 05:57 AM   #2 (permalink)
toc
Sonata97 - '97 Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Pulsar ST
90 day: 37.01 mpg (US)
Atmega328 is the chip on board, there are 13 digital IO and 6 Analog.
It's definitely able to run the OBDuino & MPGuino code without doubt, the board has 'pins' on it (instead of the header 'holes') that the older boards had - to get around that, the jumper wires will need to be female->male (depending on the LCD you are interfacing with, and how your hardware will go together).
It's nice to see a smaller board though!
The Following User Says Thank You to toc For This Useful Post:
madsoul (07-27-2011)
Old 07-27-2011, 10:08 AM   #3 (permalink)
Great... Thanks for your explanation!
I was thinking on putting Arduino + LCD inside my car's cluster, so Nano would be perfect for that.
And since I can get it by the same price as Uno, even better!
