Old 06-08-2010, 01:57 AM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Article: 1000km on a single charge
Hello -
My co-worker friend found this :
Japanese team sets new standard: 1000km on a single charge
Giving us yet another reason to get behind electric, the Japan Electric Vehicle Club recently exceeded its own Guinness record for longest distance driven without recharging, achieving a staggering 1,003.184 km (or about 623 miles).
The club's Mira EV, a modified Daihatsu Mira, was powered by a Sanyo battery system containing more than 8,320 lithium-ion batteries, the very same kind found in laptop PCs.
Running at a speed of about 40 km/h (or about 25 mph), the team employed 17 people taking turns as drivers during the course of their 27.5 hour effort. It took place at a track in Shimotsuma, in Ibaraki Prefecture.
Seems like a "Tesla-style" drivetrain if they're using laptop batteries. If they get 623 miles at 25 MPH, what would be the range based on normal usage?
CarloSW2
American Solar Energy Society
Old 06-08-2010, 09:35 AM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
CarloSW2
Much less.
It says here that the road load for a Metro is nine times as high at a steady 65mph than at 25mph. Also, the faster you discharge a battery, the less energy you can extract from it. So... somewhere around 60 miles? That's enough to get from one side of Buffalo to the other and back. I'd love to have that kind of range.
I'm curious, why did they choose 8320 cylindrical cells instead of a few dozen 60Ah prismatic cells? It seems the latter approach simplifies your battery monitoring/management scheme.
Old 06-11-2010, 01:46 PM   #3 (permalink)
The Toecutter's Avatar
Originally Posted by RobertSmalls View Post
Much less.
You neglected to include that at 65 mph you would also be travelling a greater distance per unit of time.
If load increases 9 times, then your run time, not distance, is one-ninth.
The range is probably somewhere between 150-180 miles at 65 mph. The 1997 Solectria Sunrise using batteries with half the energy density could do better than that at such a speed.
James Worden, its designer, hypermiled it in the Tour De sol and got 373 miles(previous record), but that was not at a steady 25 mph and included some highway speeds.
The Following User Says Thank You to The Toecutter For This Useful Post:
RobertSmalls (06-11-2010)
Old 06-11-2010, 02:40 PM   #4 (permalink)
Left Lane Ecodriver
*facepalm*
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Hypermiling a Tesla Roadster: 501 km / 313 miles on a single charge srortega Fossil Fuel Free 6 10-31-2009 04:21 AM
Article: pickup mileage - manufacturers are ecomodding their trucks for better MPG MetroMPG EcoModding Central 14 10-07-2009 11:49 PM
EV Charging stations article bennelson Fossil Fuel Free 0 10-17-2008 11:51 AM
Article: women use "trip chaining" ecodriving tactic more than men MetroMPG Hypermiling / EcoDriver's Ed 2 12-11-2007 01:34 PM
