Old 08-30-2010, 11:36 AM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Article: a look at the mods in Mazda "Sky" drivetrains - 18% more fuel economy (gas)
Autoweek has an article about the mods Mazda is pursuing in its "Sky" drivetrains.
In the gas engine, the author reported an 18% real world MPG improvement over the company's conventional engined car, "during a test drive that included highway driving, two-lane roads and a long run on the autobahn".
Their mods:
  • direct injection
  • high-compression ratio of 14:1 with smaller bore and longer stroke
  • "A cavity in the top of the piston has been redesigned to help with the efficiency"
  • a 4-2-1 exhaust system is also listed as an efficiency helper
  • weight reduction in the engine: "The end result was a 15 percent reduction in friction"
  • expanded lock-up capabilities in the 6-speed auto - "expansion of the lock-up capabilities--when there is no slippage from the torque converter--happens in every gear at 1,200 rpm and at speeds greater than 6 mph"
  • weight reduction in the transmission as well - about 10 lbs for the auto, 20 lbs for the manual
They almost certainly employ a taller final drive or top gear as well, to take advantage of the engine's increased torque, but they don't say so.
The article also details the "Sky-D" diesel mods:
  • reduced compression - 14:1
  • piezo injectors, variable valve lift control for the exhaust
  • weight reduction (50 lbs vs. previous engine)
  • fuel economy increases 20 percent over Mazda's previous diesels
Engineers suggested a 43 mpg (US) rating for a Sky-D powered Mazda6.
Old 08-30-2010, 12:25 PM   #2 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
Not that we will ever see it...
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
Old 08-30-2010, 01:07 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I bet we will. With direct injection they can go more the way diesels have, and it looks like that is exactly what is happening. Higher compression ratios, dished pistons, sounds like a diesel to me.
Old 08-30-2010, 02:49 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...the Aussie Holden website stated that SIDI alone was good for 7-14% lower CO2 and 7-13% better fuel economy.
Old 08-31-2010, 07:43 AM   #5 (permalink)
It would of been nice to see small turbo option on the gas version as 2L in 3000+ lb vehicle is sluggish, even with long stroke .
Thats pretty low mph for lockup (anything over 6mph/1200rpm ) . Honda has lockup in each gear to on 5AT but I don't think its anywhere near that low speed .
Does sound like decent eco vehicle, just hope there no side affects to it (not that its going to be released like that, this is just test/mod ) .
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 21 06-29-2010 09:37 AM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
