Old 10-07-2009, 08:57 PM   #11 (permalink)
EcoModding Newbie
Parachute - '03 Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Neon Highline baby!
90 day: 31.39 mpg (US)
Originally Posted by Old Mechanic View Post
Something like the T100 with a 4 cylinder and a 6 speed. It would carry the regulation 4X8 sheet of plywood if memory serves me right.
regards
Mech
A 2.5L ish 4 or 5 cylinder turbo diesel would be nice! 180hp and 300ftlbs at 2500rpm could tow 8000lbs no problem, maybe not at 80mph up a mountain but thats ok, I'd rather get 30 mpg the rest of the time...
Old 10-07-2009, 09:57 PM   #12 (permalink)
It took an Indian company to realize that you can sell a 4 cyl diesel pickup in America.
Taj Mahauler: We Drive Mahindra's Diesel Pik-Up - PickupTrucks.com News
Old 10-07-2009, 10:20 PM   #13 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Lower axle ratios will help, but the rest of it is just nibbling around the edges of the problem.
As I put it here: Piddling-around efforts bring piddling results.
You want big improvement, you gotta go to war.
1. Real aero improvements. Ask Phil Knox.
2. Diesel engines. Yeah I know the EPA hates them
3. Get rid of the dratted torque converter transmissions. Go with a manual or dual-clutch transmission.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 10-07-2009, 10:57 PM   #14 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
What do they do in Europe, where gas has consistently been >$6/gal? I bet the answer involves diesels, compact cars towing things Americans "need" a truck to tow, vans, and using the smallest truck necessary for the job.
In Germany, you can get a Mercedes-Benz Sprinter pickup: Mercedes-Benz Deutschland - Technische Daten - Maße & Gewichte
If you select the 4 cylinder diesel with the six speed stick, you get 29mpg on the Euro combined cycle, and a 2200lb payload capacity. Go with a big V6 gasser, and you get an unimpressive 18mpg.
Old 10-07-2009, 11:49 PM   #15 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
I have always argued the v8 is not allowed to get out of its own way enough and put power down. I experimented with this growing up. the 300 hp v8 with non-grandma actions got 10mpg more. The whole think needs to be scrapped. starting with drivetrain. Not one idiot thought of the benz crank v8. the counterbalanced engine is a half butts attempt at one engine being a diesel and gasoline..the diesel wins with the crazy design. They never evolved to gas properly. Today with delayed injection, the sloppy lower half sucking up 40% of every revolution needs to be smartened for injection alone as an argument. Engineers are stuck, they are capitalized, they are owned. Game over.
I have owned trucks and maintained v8s for years. All goals were to gain power..it saved fuel every freakin time, all versions even the boggy smoggers of the 1970s. today is even more difficult because of injection. Injection is a SLOB. ALL VERSIONS..ok mr.piezo?
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Interesting article: 110 mpg bio-d motorcycle conversion MetroMPG Motorcycles / Scooters 7 02-21-2011 02:39 PM
My introduction to hypermiling the Smart Ptero Hypermiling / EcoDriver's Ed 12 10-28-2008 07:32 PM
Article: 57 mpg? That's so 20 years ago SVOboy General Efficiency Discussion 17 12-23-2007 09:56 PM
Court Voids Mileage Standards for Light Trucks SVOboy General Efficiency Discussion 4 11-15-2007 11:02 PM
