Old 06-02-2010, 09:54 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Article: Ultra-Efficient Gas Engine Passes Test
Hello -
While reading DIM's thread I stumbled on this :
Technology Review: Ultra-Efficient Gas Engine Passes Test
Transonic Combustion, a startup based in Camarillo, CA, has developed a fuel-injection system it says can improve the efficiency of gasoline engines by more than 50 percent. A test vehicle equipped with the technology gets 64 miles per gallon in highway driving, which is far better than more costly gas-electric hybrids, such as the Prius, which gets 48 miles per gallon on the highway.
The key is heating and pressurizing gasoline before injecting it into the combustion chamber, says Mike Rocke, Transonic's vice president of business development. This puts it into a supercritical state that allows for very fast and clean combustion, which in turn decreases the amount of fuel needed to propel a vehicle. The company also treats the gasoline with a catalyst that "activates" it, partially oxidizing it to enhance combustion.
Fuel heater + more pressure?
Here's the company :
Transonic Combustion | Ultra-high Efficiency Fuel Injection Systems
CarloSW2
American Solar Energy Society
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
mcrews (06-03-2010), robertwb70 (06-02-2010)
Old 06-02-2010, 10:12 PM   #2 (permalink)
1991 Metro 1.0 Auto - '91 Metro Lsi Auto
90 day: 38.87 mpg (US)
I wonder how hot and how much pressure it takes to make a difference? and how much heat can conventional injectors handle without damage?
Seems like it would be easy to heat the fuel with the exhaust, electric fuel pumps are available for 100+ PSI but re-tuning the ECU would be the real work involved but even that can be done.
Old 06-02-2010, 11:46 PM   #3 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
color me sceptical -
since the mass of the fuel is about 1/15th the mass of the air
in the air fuel mixture prior to combustion
it would seem that air temperature would be far more critical and have a much Larger impact than
fuel temperature
and there has been no small amount of testing and experimentation regarding WAI
which does NOT yield similar test results claimed by this company ....
The Following User Says Thank You to mwebb For This Useful Post:
Frank Lee (06-03-2010)
Old 06-03-2010, 01:13 AM   #4 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Gotta say, I just checked out the Board of Directors.....Robert Lutz just got on and Ray Rothrock (who has a VERY impressive Venture Capital background) is also on.
This is no Telsar Motors.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-03-2010, 01:50 AM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Oh please
50+%?!?
How complete is the combustion event now? 99%?
Old 06-03-2010, 06:09 AM   #6 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Yeah, I suspect that increasing by 50% means that they decreased what is not completely burned by 50% -- so it went from 99% to 99.5%?
Old 06-03-2010, 10:37 AM   #7 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
A big problem with leaning out the fuel air mix is getting a complete burn, that is why Honda's CVCC engine of the early '80's got better mileage is the rich mix that was needed for ignition was next to the spark plug, the rest of the combustion chamber was a very lean mix that would otherwise not ignite from a spark and the over all mix was leaner then normal.
I think it's the same idea as direct injection, have the fuel ignite without fully depending on a spark.
Old 06-03-2010, 11:07 AM   #8 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
They are talking about engine efficiency, not burn efficiency.
A few things to note:
1. its direct injection.
2. uses compression ignition
3. No throttle plate (lean burn)
4. They are still not sure of long term durability
5. Gassoline at temperatures and pressures to be in a super critical state is a little scary.
Old 06-03-2010, 11:29 AM   #9 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Oh- HCCI or some variant thereof?
Homogeneous charge compression ignition - Wikipedia, the free encyclopedia
Old 06-03-2010, 06:08 PM   #10 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Sooooo........
They took a diesel,
Lowered the compression,
And fed it gasoline........
Hasn't this been tried many times before???
Maybe with new 3D fuel map computers it will work this time.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
convert gas engine to run on ethanol jesse.rizzo Fossil Fuel Free 7 01-28-2008 12:05 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
