Old 09-03-2009, 05:03 PM   #1 (permalink)
janvos39's Avatar
FKB - '03 Focus DAW/FFDA1/5PFDMW
90 day: 45.7 mpg (US)
Atkinson cycle
I am interested in looking into the possibility of making a variable inlet valve timing to run the Atkinson cycle as used in the Toyota Prius.
Who has details of the timing variation that Toyota is using for the Prius with their VVT-i valve control system? Is the workshop manual more detailed than the commercial leaflets?
Old 09-08-2009, 03:15 PM   #2 (permalink)
janvos39's Avatar
I found what I was looking for. A friendly Toyota dealer made this copy of the manual.
It shows that the Prius inlet timing is shifted over an angle of 41 degree from maximum torque to best FE.
Now it is time to make a mechanism for the Suzuki Burgman to realise this kind of inlet cam change . At 70 MPH I only use 1/4 turn on the throttle so it must be possible to do the same as the Toyota Prius.
Old 09-08-2009, 03:51 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
You probably know, but to take full advantage of the atkinson cycle you'll need to increase the compression a fair amount too.
Old 09-08-2009, 04:07 PM   #4 (permalink)
janvos39's Avatar
My plan is to change the engine capacity of my Burgman from 385 cc to 300 cc by putting a cylinder and piston in of the Burgman 250. They almost fit. Only need to do some bushing in the connecting rod. By making the bore smaller I get some more compression with the 250 cc(bore 73 mm) head. Not sure if I go to the full 13:1 of the Prius. Other users of Atkinson cycle report lower compression ratio.
Potential engine mod? Otto to Atkinson conversion AndrewJ EcoModding Central 78 12-02-2010 07:02 AM
Why no diesel Prius? alohaspirit Hybrids 80 12-09-2009 06:06 PM
Atkinson mod? elhigh EcoModding Central 5 04-23-2009 09:00 PM
Duty cycle of fuel injectors Gregte DIY / How-to 9 05-22-2008 09:21 PM
