Old 06-07-2009, 07:17 PM   #21 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Originally Posted by gascort View Post
If my logic is correct, my Optima Yellow Top D34/78 has 55AH of capacity. It has been fine to get me to and from work. Since this new battery I'm adding in series is 4V out of the total 16, it will only be providing 1/4 of the amps to the circuit, so its 9AH * 4 = 36 effective amp hours relative to what the optima was providing.
Nope.
If you have the batteries in series, the current flowing through each will be the same. To use a plumbing analogy, voltage is like pressure, and current is like flow rate (how many electrons pass a point per second, if you like). So if you draw 18A while driving, your 55Ah battery will last 3 hours, and your 9Ah battery will last 0.5 hours. The best case scenario is that your 16V will slowly droop as the batteries discharge, and after 0.5hr, the 4V battery will be at 0V and the system will be at 12V. The worst case scenario involves internal resistance rising in the 4V battery.
If your starter draws 200A, the terminals on your 4V battery need to be rated for 200A as well.
Hmm, that leads to an interesting idea. Why not just place a 2.3V NiMH battery in line with the fuse that goes to the ECU, or whichever system you're trying to fool? You won't blow out headlights or anything. If all you need to fool is the alternator warning light bulb, the battery would probably go weeks between recharging.
Old 06-10-2009, 03:44 AM   #22 (permalink)
Yaris - '07 Yaris Liftback
Do alternatorless cars use magnetos? I am honestly intrigued, never heard of this.
Old 06-10-2009, 08:15 AM   #23 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Going alternatorless is a mod we do here on EM. No cars come without alternators.
Old 06-10-2009, 09:08 AM   #24 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
No cars... except certain hybrids. :P
Old 06-12-2009, 04:40 PM   #25 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Arrgh! I just blew my inverter by hooking it up in reverse.
I am going to take it apart because the manual says it has internal fuses. Hopefully that's all that's wrong.
I'm going back to the 3-6 volt trojans for now.
It looks like I'm headed for a very good tank. I found some info while searching for 16V batteries that racers run higher voltage to get a hotter spark for higher HP.
Mpguino is still not working. Must be a bad solder.
Old 06-15-2009, 05:13 PM   #26 (permalink)
CM400E - '81 CM400E
Did you ever actually confirm that higher voltage returns higher mileage?
Old 06-18-2009, 04:37 PM   #27 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
Just posted my latest fuel log and for this tank, a mix of hilly bowen, hilly city and some highway, I'm getting 24.36 combined. My usual average is 22.5 mpg. That's about 8% better. This is very encouraging because I did about double the Bowen driving to city/highway ratio. My last tank I kept voltage up only half the time but it shows an improvement as well.
This is the first tank where I managed to have the voltage up 90% of the time. I kept it at 14-14.5 but I think 18 volts will give even more gains. I found some info on racing sites where they were running 18v for more HP.
I keep hoping someone with a more consistent driving routine will test the high-low voltage issue. I rarely have the chance to do any benchmark A-B-A stuff here.
This really is important for alternatorless driving because all the results on this site are for going from 14.5 to 12V or less and the gains were about 10% so if there is another 8% to gain from alternatorless by keeping the voltage up then we have a much better ecomod here than previously thought.
Any takers?
Old 06-18-2009, 04:50 PM   #28 (permalink)
CM400E - '81 CM400E
When I posted my alternator disable on cmpg, a user there suggested running a DC to DC converter just for the ignition coil to get the voltage for the spark up. I doubt the rest of the system cares about voltage as much. Would be interesting to test it.
Old 06-18-2009, 05:03 PM   #29 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
The DC-DC converter is the way to go. I plan to do it as soon as the budget allows and if I can find a 12-18V or 12-14.5 DC-DC converter. The wiring would be a pain but worth it for the savings and simplicity.
I think the fuel pump could use a boost as well. At least keeping it at 14.5. I'm sure fuel vaporization is much better if it can keep a high pressure. (another thing to test)
Old 06-18-2009, 05:08 PM   #30 (permalink)
CM400E - '81 CM400E
I'm pretty sure pressure regulation is all mechanical.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 42 03-28-2010 03:24 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
can you use a DC motor controller to charge car battery from a higher voltage battery modmonster EcoModding Central 9 02-13-2009 08:14 PM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 10:13 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 04:16 PM
