ATX + external lube pump (RV type) = Bump start-able ATX?
Hi guys,
Im looking for info & brainstorming a bit here. The idea is to be able to back drive an ATX (for Regen purposes, but will progress on that train of thought later). i know this system is tried & tested for Towing behind an RV, but its purpose is limited to providing oil to the ATX bearings. My thinking is, can i use this system to backdrive the ATX input? essentially be able to bump start the Engine(if the ATX is not in N obviously) if i have this installed as per the RV towing spec?. Thanks guys, like i said, im just brainstorming here, any input is appreciated.:thumbup: |
