Old 07-30-2010, 02:53 PM   #1 (permalink)
echo max - '96 Maxima GLE
90 day: 30.22 mpg (US)
Mrs Hitler - '03 beetle GLS Turbo
auto air dam
so i was thinking the other day i added an air dam to my car and it got hot real quick and noticed the fans alot more. the car obviouslly already knows when the car is to hot. so what if i could open the air dam like a door and close it automatically using mini hydrolics. with enough of them it would be able to handle the force of wind at 60+ mph. this could be done on a switch or i was thinking since the car knows when it needs to be cooled down why not use the fans power to open or close the grill block. make it a auto smart car so it just cools it self when it knows it needs to.
has anyone ever tried something like this
Old 07-30-2010, 03:35 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...yes, it'll work, but using pneumatics (air or vacuum) might be easier than using hydraulics...and safer.
...FWIW, this "trick" is also going to be seen on the 2011 Cruze Eco model, and is already in use on some BMW models.
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 5 10-09-2009 11:09 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
