Old 11-16-2008, 05:32 PM   #1 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Auto Intermittent Deer Horn - How to?
  • I drive 150 miles each night (1:00 AM to 6:00 AM) in the boonies of North Central South Dakota.
  • Most all of this is narrow two lane roads with lots of deer, raccoons, jack-rabbits and the rare, escaped, all-black/stealth cow.
  • Farm yards located with in 1/4 of the road are about 5 miles apart.
I would like to out fit my car with an intermittently beeping horn that can be operated via a toggle switch. Ideally the horn should emit short (1/8-1/4 sec.??) beeps about once each second.
I need an electric horn, a (HD) horn relay, wire, fuse & fuse holder toggle switch and ...
An suggestions for a cheap, ready made actuator circuit? Intermittent wiper are too slow. Emergency flashers are 50% on 50% off and speed is dependent on load.
Old 11-16-2008, 07:38 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Cherry Bomb. Loud pipes save lives
Old 11-16-2008, 08:02 PM   #3 (permalink)
Thanks for the thought, but loud pipes also wake up people in houses trying to sleep. There are five little, quiet towns where I deliver newspaper bundles. I only want to be noisy for 80-85% of the route. I could get one of those european style, alternating high note - low note sirens - but that would be overkill. (Not sure it would be legal either.)
Old 11-17-2008, 12:01 AM   #4 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
You need a timer.... Like the one I used for turning a cheap digital camera into a time lapse camera
Quick and Easy Electronic Time Lapse
If you can solder, the kit goes together in a few minutes (at least for me) - aquick google search, and I found a place selling the same timer I used
Adjustable Interval Timer MK111 - VETCO.NET
That's how I'd do it cheaply...
Challenge me, or correct me, but don't ask me to die quietly.
Old 11-17-2008, 01:14 AM   #5 (permalink)
If you understand all this than it will be simple to build and you wont find a cheaper way I dont think. You will need a transistor on your output to power your relay.
Old 11-17-2008, 08:35 AM   #6 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
This kit is great! I used it to control the A/C compressor on my old car after the $1500 computer quit doing it.
Old 11-17-2008, 05:50 PM   #7 (permalink)
Thanks for the thought, but it's all greek to me.
If you can solder, the kit goes together in a few minutes (at least for me) - aquick google search, and I found a place selling the same timer I used Adjustable Interval Timer MK111 - VETCO.NET
Thanks. Not exactly what I want, but close enough - I'll probably order the kit.
Spec. for the kit is
  • output relay with dry switch-over contact: 3A/24V
  • pulse time adjustable: between 0.5 and 5 sec. (0.2 sec - 2 would be better.)
  • pause time adjustable: between 2.5 and 60 sec. (1.0 - 6 sec or more would be better)
  • power supply: 12V DC / 100mA
  • dimensions: 1.6" x 3.4"
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Design competition: hybridize the Tuk Tuk (auto Rickshaw) MetroMPG EcoModding Central 4 02-07-2009 03:23 AM
Louder horn and a pedstrian horn... Sean T. Off-Topic Tech 3 11-15-2008 01:29 AM
Presidential Candidate Views On Auto Energy Conservation Matt Herring The Lounge 2 09-06-2008 12:48 AM
DIY:Install Intermittent Wipers on a VX/CX TomO DIY / How-to 0 11-14-2007 03:34 PM
