Old 07-19-2009, 12:02 AM   #1 (permalink)
Turtle - '01 Swift Plain Jane
90 day: 40.92 mpg (US)
Turtle Auto Trans info needed!
I have a 2001 Swift 1.3 AT and have two questions; first there are two hoses running from the trans to/from the radiator to cool the ATF, does anyone know which is which or do I start the car with one hose disconnected and blow fluid everywhere? I am installing an inline Trans Fluid Filter and it is directional.
Second; are Auto Transmissions from earlier years (1990-1995) forward compatible to my 2001 ?? If not, are the internals compatible assuming the exterior mounts etc... are different??
Thanks!!
Old 08-15-2009, 09:36 PM   #2 (permalink)
Car - '06 GTO
truck 2 - '99 S10
Usually the cooler for an auto trans is setup in the return to the pan from the pump/valvebody.
My experience has shown that the OEM's use a counter-flow arrangement (this has not been tested on a metro). ATF flows the opposite direction of the coolant. A study of heat exchanges will show you that this type of heat exhanger will give a better cooling capacity than fluids flowing the same direction, so this makes sense.
An easy way to check this would be to see which line is hotter after a drive, the difference may not be much.
It's not likely that the earlier transmissions are a direct swap, by 2001 most automatic transmissions had electronic controls. Earlier models may or may not have had this, but the electronic controls they have will most likely be different.
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
WAY off topic. Arduino info needed STEELBREEZE Off-Topic Tech 11 03-27-2009 08:32 PM
GM trans swap, lack of info Unforgiven DIY / How-to 9 12-06-2008 07:53 PM
Disengaging auto trans for coast. beatr911 EcoModding Central 18 06-24-2008 05:04 PM
