Old 04-06-2010, 08:03 AM   #1 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Autoenginuity scanner
At $400 plus your own Windows laptop, this is a pricy instrument. However, it appears to cover the 2001-03 and I understand 2004-09 Prius systems. For the 2010 Prius, it reads a 20+ list of standard OBD-II data fields that easily includes:
  • ICE rpm
  • mass flow
  • speed
  • accelerator position
  • barometric pressure - both manifold and absolute
  • coolant temperature
  • EGR status
sub-second sampling rates
It has multple dislays and runs fairly easily. Although not as small as a Graham or dedicated performance scanner, it provides great flexibility as well as diagnostic support for repairing faults. Compared to the $250 Sears brand, scanner, this is a very capable tool.
Bob Wilson
Local record
Old 04-08-2010, 09:49 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...hm-m-m-m, wonder when the SGII might get upgraded (again)?
...would be nice to have a streaming USB, pass-thru, data port so we could record directly to either a thumb drive or laptop computer.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 04-14-2010, 10:01 PM   #3 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
autoenginuity 8.2
for the prius
you will need a tool at least as capable as AE just to bleed the brakes
a feature AE has which is not mentioned ,
in the in the system test menu for the ABS module
not the activation menu.
and
don't forget the free tag along SpeedTracer which can be used to provide real time fuel economy , among other things .
every thing is recordable as long as the hard drive has remaining space .
Scan gauge is generic OBD2 only ,
there are no enhanced features .
there really is no comparison between the two ,
like comparing roller skates to a new audi
Old 05-10-2010, 05:05 PM   #4 (permalink)
I just picked mine up today!
Having used both Equus and the Sears models before, this is money well spent on the AE. You'll get a ton of usefull data that a typical code reader just doesn't read. I like its ability to record specific bahaviors that can be shared with others (helps, when you need expert advise). Anything they don't cover, I'm sure you could submit a request for...
Also, take a look at this. SpeedTracer Stage I
Old 05-13-2010, 01:30 AM   #5 (permalink)
mwebb's Avatar
speed tracer version 5.o
the current speedtracer version is
5.o -
the screen caps shown are from 4.2 but in 5.o the upper limit has been raised in the FE screen to 80mpg
your version should have 5.o which was introduced around AE 8.1
Old 05-13-2010, 10:57 AM   #6 (permalink)
That's interesting, AE 8.2.1 came with ST 4.2. Per their pressroom, ST 5.0 came out with AE 8.0. I'll give them a ring to see what I've missed.
[Revised]
I called and spoke to AE and it turns out that ST 4.2 is the latest/greatest version.
So, I'm guessing that they updated their news page before the decision was made to release it as an updated minor revision instead of a major version change? As I got off the phone with them, they were going to update their web page.
Here's a what looks to be a good tech link I came accross on PSN.
http://forum.gopowerhungry.com/autoe...stic-software/
Old 05-15-2010, 10:12 PM   #7 (permalink)
mwebb's Avatar
with a 1996 geo metro 10g , driving at around 45 mph peak in traffic .
for unknown reasons "they" must have switched back to version 4.2
i did identify a problem and show "them" when "they" first released 5.o ....
but
i have 5.o ,
see the "max" value on the FE scale and see the "about" screen cap showing 5.o .
i know "they" are almost always crazy busy working on the next release and this must be on the back burner for now ?
or choice c , i do not know
Old 05-22-2010, 08:53 PM   #8 (permalink)
mwebb's Avatar
Escan LTFT with SpeedTracer 5o screen caps
driving in heavy traffic , stop and go
logging / graphing LTFT with Escan and from an earlier trip covering the same ground
speedTracer screen caps included
i tried to use AE and Speedtracer at the same time
did not work
Old 05-23-2010, 11:10 AM   #9 (permalink)
I haven't tried this yet myself on account of needing to get my variables entered. My guess is they use the same interface.
This would be a good feature request - ask them to come up with some sort of mirror driver that would allow sensor polling from more than one application.
Happy birthday to us! EcoModder turns two (December 3). MetroMPG Forum News & Feedback 145 01-19-2012 07:22 PM
Graham mini scanner - Quick User's Guide bwilson4web Hybrids 2 11-27-2009 08:58 AM
tahoe last gen bought scanner tahoescanner Introductions 2 08-03-2008 11:22 AM
