Maybe instead of shifting in or out of gear, use a one way clutch that does not let the wheels drive the engine? Then you chould switch the engine off any time the throttle was closed, automatics already have a switch on the accelerator to use for this. You would want to use a micro to do the control though and work out some algorithim.
