Old 11-02-2010, 09:58 AM   #11 (permalink)
Yukon XL - '03 Yukon XL SLT
After searching for more data I found info on what American refer to as Dinghy towing, from an RV/motorhome.
It seems the 2003 yukon can be flat towed with xfer box in neutral, 2004 yukon is just towable as is.
My dilemma is mine was built in 2003, but appears to be 2004 spec. If i can confirm it is the one listed on 2004 then I could even EOC
Old 11-02-2010, 10:06 AM   #12 (permalink)
Just to add, mine is canadian spec
Old 11-02-2010, 12:00 PM   #13 (permalink)
The owners manual only says to leave the car in drive because you are more likely to cook your brakes without engine braking
Old 11-02-2010, 12:20 PM   #14 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
All that means is, "Don't be stupid. If you are, it's not our fault since we told you not to."
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 11-02-2010, 11:23 PM   #15 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
I own an Infiniti Q45 2002. I bought it at 40k. I have coasted w/ engine on for the last 5 yrs. I have 219,000 miles and still have the origial transmission. I can shift in and uot of neutral while coasting at speed. I agree that each vehicle is different but I can speak for infiniti.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-03-2010, 09:36 AM   #16 (permalink)
I found this site Free VIN Decoder - Vehicle Identification Number Report
You type in your VIN and it gives you a shed load of info on your specific model.
Seems I have the 285bhp engine from 2003 so I can coast, but not EOC
Old 11-07-2010, 07:00 AM   #17 (permalink)
I've spent a couple of days coasting on my journey to work. The problem is I've been working nights and the weather has been rough. So coasting with headlights, 3 wipers, heater, heated seat, heated mirrors and radio on have taken their toll.
I went to start it the next day and it was almost flat, it just started, if it hadn't started any savings I made would have been wasted in lost pay for being late.
So I'll probably leave the coasting for daytime dry days when I only have minimal electrics running.
Old 11-07-2010, 04:02 PM   #18 (permalink)
Aveo - '08 Aveo LS
I tried it for a week. My gas milage increased, but I just keep getting stressed by obsessing over it. I also was anxious about damaging the trans.
I stopped doing it. The anxiety wasn't worth it. I drive an automatic chevy aveo. Not the best fuel efficient vehicle, but atleast its better than my last car.
Old 11-10-2010, 11:34 AM   #19 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Ben if you were costing and then the next day you had a hard time starting the car then you need to get that problem fixed. You should not have a problem starting as the alternator will still charge the battery when coasting, check the grounds for the starter and to the battery if those are fine and clean it might be time to get a new battery.
I move at the speed of awesome.
Old 11-10-2010, 12:00 PM   #20 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
FWIW -- the 2011 Chevy Cruze Owners Manual says the automatic transmission model can be dinghy-towed (flat-towed) in neutral at moderate highway speeds as long as the vehicle is started and driven once per day.
...that's the GM Hydro-Matic 6T40 (RPO code MH8) 6-speed automatic transmission, which is also used in Malibus and Buicks.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
Solution for coasting an automatic transmission: external oil pump MetroMPG EcoModding Central 16 03-11-2011 01:16 AM
Any damage to auto transmission when coasting in Neutral sl2eggplant Hypermiling / EcoDriver's Ed 23 10-01-2010 02:41 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
NO Damage to auto transmission by EOC ScottC33 Hypermiling / EcoDriver's Ed 35 07-09-2009 02:42 AM
