Automotive X-Prize: "The Very Light Car" (also very aero) with conventional engine
3 Attachment(s)
Alerted to this via ABG:
http://www.blogcdn.com/green.autoblo...ight-car-7.jpg (You know you're an EcoModder when you show the rear view first :)) The company, Edison2, is located in Lynchburg, Virginia, and ruled out an EV drivetrain primarily due to the weight of batteries. We don't have any details on the weight or CdA, but they're dealing with an order of magnitude change in some areas on the weight side of things: Quote:
http://ecomodder.com/forum/attachmen...1&d=1263415230http://ecomodder.com/forum/attachmen...1&d=1263759499 Source: Edison2: The Very Light Car (X PRIZE Contender) - Gallery - The Very LightCar Space frame: http://ecomodder.com/forum/attachmen...1&d=1263415230http://ecomodder.com/forum/attachmen...1&d=1263759499 Unfinished body shell: http://ecomodder.com/forum/attachmen...1&d=1263415265http://ecomodder.com/forum/attachmen...1&d=1263759499 ABG called it a "poor man's Aptera". Not very nice! (Probably not true, either.) Coincidentally, there's an Aptera in the left side of the above photo. Web site: Edison2: The Very Light Car (X PRIZE Contender) - The Very Light Car |
i want it.
Edison2 Very Light Car
Hi Darin,
Ya beat me to it: This car has come a long way since the last one we saw -- it is very similar to the Aptera 2e in some obvious ways, and it quite different in other ways. http://www.blogcdn.com/green.autoblo...ight-car-3.jpg (click on picture for link) http://www.blogcdn.com/green.autoblo...ight-car-2.jpg http://www.blogcdn.com/green.autoblo...ight-car-7.jpg http://www.blogcdn.com/green.autoblo...ight-car-8.jpg The similarities are: streamlined body with outrigger wheels, and two seats side-by-side, composite construction. The main differences are: ICE-only power train, 4 wheels, 1 entry door. I like parts of this, but others are a bit odd. So, what do you think? |
Nice, aero, small engine, it should be able to do a long hiway trip more efficiently than any hybrid. Low weight might make it competitive in the city too.
does the driver door swing up like a delorean? ..or like a lamborghini?
I was wondering how they made the suspension work within those fixed aero struts -- here's what appears to be the rear suspension:
http://www.edison2.com/picture/rear%...tureId=4066690 The shock sits closer to the car, and the top is braced on the chassis. I guess that there are two large diameter bearings on the inner end, and the whole tube rotates as the wheel moves up and down? They seem to not be showing the outer swing arm? This set up bothers me -- there must be a lot of torque and bending on this tube... And I also like the "very light wheels": http://www.edison2.com/picture/our%2...tureId=4066689 Darin, that engine certainly looks unique -- there is a heck of a lot of plumbing! It also looks to be a turbocharged 2-stroke? |
Not sure about the door. Might check their gallery: Edison2: The Very Light Car (X PRIZE Contender) - Gallery - The Very LightCar
One thing I noticed: doesn't seem to have any (conventional) suspension. |
They are not revealing the key spec: how much does it weigh?
It has an extra wheel.
lol, it has two extra wheels for that matter, but I still like it :)
where's the tow hitch? |
