Old 08-23-2009, 10:17 AM   #21 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
LOL, share the code and schematic online somewhere and I'll tell you if you are right
Old 08-23-2009, 06:34 PM   #22 (permalink)
You sem to be making something of nothing. There is no secret about how how FuelSmart works. It monitors TPS and MAP. When TPS shows that the throttle is open, and vacuum is above a certain value, the output LED lights. Both TPS and MAP thresholds are user-settable; the MAP setting is a major factor in the quality of the outcome. There are a few filters and delays inthe software, and some input protection in the hardware, but that's basically it.
For something so simple, in testing I was amazed at how well it works.
Old 08-24-2009, 07:35 PM   #23 (permalink)
Part 2 is now out - Browser Warning
Old 08-24-2009, 07:38 PM   #24 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Thanks for the update!
There must be an issue with autospeed's title system since it shows up as a browser warning
Old 08-25-2009, 10:51 AM   #25 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...because I haven't actually *tested* the device myself, I really shouldn't be making comments, but I DO want to feedback these thoughts:
1) the article needs to show some test data that supports the product claims.
2) the pictures should be "referenced" (ie: Fig. 1, etc.) to the text body.
3) the article needs to summarize the product components (ie: a Parts Listing legend, etc.)
...meant as "constructive" criticism only (and hopefully taken only as such).
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 08-25-2009, 12:26 PM   #26 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by Julian Edgar View Post
Fair enough. But I am reluctant to recommend driving in a way that is illegal for most of my readers.
That's completely understandable.
But re-defining an established driving term to avoid advocating something that happens to be illegal where you live will only cause confusion to your readers who Google the term and/or encounter it elsewhere. I maintain it's not gliding! It's "pulse and fuel cut". (/end of rant against revisionism.)
(FYI, where I live there is no law prohibiting gliding/neutral coasting... but that's beside my point.)
One other thing I'd liked to have seen - as Old Tele Man menioned - was comprehensive details of the test where the 15% improvement in fuel economy was found.
Darin
Old 08-25-2009, 06:49 PM   #27 (permalink)
1. The article does show test data - it says, over a car driven as most people would, I gained a fuel economy improvement of 15 per cent on a particular urban route. I deliberately left it as open as that; there are too many variables in cars, drivers and routes to be more specific. In fact, I did the test really to demonstrate to myself that I wasn't just imagining things, that in fact it was repeatable and the gain was major.
2. We don't run photo captions or specific photo references - most people seem to be able to follow our aticles OK.
3. I don't understand why a parts listing is necessary - it's not a kit.
Old 08-25-2009, 06:55 PM   #28 (permalink)
I am a bit puzzled why people here are negative.
1) The science behind the project is quite sound
2) I have never seen anyone before using an approach just like it
3) I have given enough information that suitably electronic proficient people can make their own if they don't want to buy the eLabtronics one. (And you can always use a MAP sensor from a wrecker, so it can be used in all EFI cars, not just those that already have a MAP sensor.)
4) It can improve the fuel economy of most drivers
Aren't all those things good?
Old 08-25-2009, 07:00 PM   #29 (permalink)
Dartmouth 2010
SVOboy's Avatar
People can be skeptical because we get a lot of BS on here (you can see the recent 8 valve engine thread for an example of this) so pretty much everything gets taken with a grain of salt.
Personally, I love autospeed and the fact that you actually take on issues involving fuel economy, so I say keep up the good work. Even if we're skeptical at times we're all here to improve and work to better our knowledge of the issues and techniques, so keep that in mind.
Old 08-25-2009, 07:13 PM   #30 (permalink)
...beats walking...
...since we're much closer to MISSOURI here in USA than you are there in AUSTRALIA, you'll have to endulge us and SHOW us (well, me for one) where and how you "...gained a fuel economy improvement of 15 per cent on a particular urban route."
...for instance, I have no idea whatsoever of what you specifically mean by "urban route." I'm sure what I perceive to be "urban" here in Arizona maybe be similar, but not the same, as what you mean. And, what were the speeds and times-to-speed and coastings that comprised your particular urban route (what made it particular?).
...and "negative" shouldn't be confused with "skeptical." Hence, the Americanism: "...I'm from Missouri, so you'll have to SHOW me."
