Old 08-10-2009, 06:45 PM   #1 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Astra ECO4
90 day: 61.03 mpg (US)
Average MPG drop :(
Am well disappointed. Before doing the following, I've been getting 63MPGus average. But now after fitting new tires on the front of my car & inflating all tires to 50PSI, put back in my seats and installing cruise control, now my FE has suffered - the average has fallen down to 60MPGus. Does new tyres and the extra weight from the seats really do make that much difference? I miss the 70MPGus I got a while ago...
Or could it be all the rubbish weather we're getting in the UK lately...?
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Old 08-10-2009, 06:55 PM   #2 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
Depends what type of tire you deleted and what type of tire you added. If you removed LRR tires and added a HRR tire you will lower mpg. If it's the same tire you will have a breaking in period for the new tires that will lower mpg. Are all the tires the same size (just asking as they could throw off the odometer as well...hoping they are all the same size).
Also, any added weight in the car will lower FE. Your seats could be an extra 50, 75, 100+ lbs. that you are dragging around in the car now.
Both of these events (plus any bad for FE weather) can all have negative effects on your FE.
The Following User Says Thank You to Matt Herring For This Useful Post:
Eddles (09-06-2009)
Old 08-10-2009, 07:00 PM   #3 (permalink)
Eddles's Avatar
Old tires weren't fuel savers, while the new ones are.
Is there any rough figure of how many less MPG for each lbs that are added on? I.e. 1% less MPG for 50 lbs added on?
Thanks!
Old 08-10-2009, 07:03 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
New tires also have higher rolling resistance than worn in tires. Give them some time to break in and your MPG should go back up.
Also, cruise control, in my experience, isn't as good for fuel economy as driving with load and paying careful attention, so that might have some bearing on the situation.
The Following User Says Thank You to SVOboy For This Useful Post:
Eddles (09-06-2009)
Old 08-10-2009, 07:04 PM   #5 (permalink)
That being the case on the new tires I would give them some time to break in before making any judgments on their effect on FE. What are the specs on the tires that are on the car now (front and back) and what did you replace with them?
Check this thread out about weight reduction in the car...read down through the posts to see what others have seen in FE in regards to weight...
Weight Reduction
Old 08-10-2009, 07:10 PM   #6 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Weight does very little on the highway. I can't remember the "formula" for weight added and gas mileage.
The Following User Says Thank You to MadisonMPG For This Useful Post:
Eddles (09-06-2009)
Old 08-10-2009, 07:11 PM   #7 (permalink)
Eddles's Avatar
I guess so. How long is a break-in period, normally?
The motorways between the city where I live and where I work are completely flat - and I mean flat. The cruise control holds the speed much better than I do - it rarely devitate from the set speed more than 0.5mph, where I deviate from the set speed a lot more so I spend my time accelerating/deaccelerating to keep to the set speed. I guess I could do a tank without CC to see if there's any difference, however holding the accelerator pedal in the same place for 800 miles a week isn't forgiving to my ankle!
Thanks for link, much appreciated!
Old 08-10-2009, 07:14 PM   #8 (permalink)
Eddles's Avatar
Hmm. I suspect the seats in my car are about 60KG for the front passenger and all rear seats. That would translate into 130lbs and that's a 5% weight reduction for my car, which might translate into 0.5-1MPG. Might need testing, but getting 800 miles out of a tank means really long test periods!
Thanks again for help.
Old 08-10-2009, 07:14 PM   #9 (permalink)
800 miles of holding a constant speed certainly is a little painful...but how about breaking your 800 miles into smaller segments if your ankle doesn't allow for it over 800 miles of driving. Something like 20 miles of cc then 20 miles of your foot.
Do you have any instrumentation to monitor FE? This would show you exactly how your cc is doing for you vs. your foot.
Old 08-10-2009, 07:19 PM   #10 (permalink)
Eddles's Avatar
Very good suggestion. I've brought a MPGuino and have assembled it but haven't installed it yet. The amount of wiring in my car is scaring me! I haven't figured out where to tap the MPGuino into - I don't have the correct wiring information for the engine and to get that might take me a lot of time. I might get around to installing it in early September when I get back from my holiday in late Aug.
And unfortunately no, I can't have a OBDII based display as my car doesn't have an OBDII port.
Probably best if I wait until I install a MPGuino and check the thermostat (the engine takes over 10 mins to warm up) before asking for help here I guess.... Sorry!
101.5 MPG on my 2003 Ninja 250!!! theycallmeebryan Motorcycles / Scooters 250 02-10-2012 08:05 PM
free OBD2 software with MPG calc whitewiz Instrumentation 5 02-05-2012 09:40 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
ScanGauge Average MPG Question... Sean T. Instrumentation 8 08-11-2009 11:31 PM
AC on the entire time and I got my best MPG average ever?? regor Hypermiling / EcoDriver's Ed 12 06-24-2008 01:55 AM
