Old 05-24-2009, 03:26 PM   #1 (permalink)
Question b2000 electric fan conversion
im planning on doing an electric fan conversion. i have a 97 neon which i plan to pull the parts off of. wondering if the radiator and fan from the neon will be suffient coolant for my b2000 4 cylinder and what problems I might run across. not worried about the ac plan on removing all the ac components from the b2000.
Old 05-24-2009, 10:20 PM   #2 (permalink)
allc0re's Avatar
The Truck - '00 Ranger XL Ext. Cab
90 day: 24.94 mpg (US)
Send a message via AIM to allc0re Send a message via MSN to allc0re Send a message via Skype™ to allc0re
You are using both the fan AND radiator from the Neon? Why not just use the fan and keep the original radiator on the B2000?
Old 05-25-2009, 01:14 AM   #3 (permalink)
will probably wind up doing that actually. just have to figure out how to set it to come on when is required.
Old 05-25-2009, 10:19 AM   #4 (permalink)
allc0re's Avatar
You might look here. I'm doing the same only on a Ford Ranger.
Electric Fan Conversion (Ford Ranger)
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Electric vs. belt driven cooling fan Gregte EcoModding Central 58 04-11-2012 02:20 PM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 59 10-25-2011 07:30 AM
Electric Fan Conversion (Ford Ranger) allc0re EcoModding Central 12 07-08-2010 11:14 PM
Extreme Electric Motorcycle conversion for Publicity/Charity bennelson Motorcycles / Scooters 5 11-18-2008 04:09 PM
