Baby template car for DARKO 2016
I've set my mind to a return trip to DARKO Technologies wind tunnel in 2016.
I've thought of at least 16 additional mods for the T-100 to test. Since I'm going,it would be efficient to have at least 1-additional vehicle to test while I'm there (like we did with Gary's Prius). I figured out that a 1/3rd-scale 'Template'-mobile will fit in the back of the T-100. She'd be 21" high,42" wide,and just shy of 8' in length.Built up from plywood,foam,and fiberglass,she wouldn't weigh much.I've already located some 'scale' wheels at Harbor Freight Tools. The 76-mph airspeed at DARKO is plenty enough to achieve critical Reynolds number and accurate Cd. The model would be a way to verify the 'Templates' actual aero characteristics. -------------------------------------------------------------------------- Also,if there's a member in the Salt Lake City area with a bone stock, 1st-gen Honda Insight,it would be great to do a meetup at the tunnel and throw your car onto the load cells and see how it's Cd compares to the A2 value from North Carolina.I'd cover the cost. -------------------------------------------------------------------------- It allows one year for fabrication and even at my glacial pace,I think I can get it all ready by then.:p |
Can't wait for the results!
Care to elaborate on the 16 mods you want to do to the 'yota? |
That sounds great. I would also like to know the 16 mods you are planning for the T-100.
This is a great idea. My request is that you consider a geodesic construction. It can be laid out as a flat pattern with darts and cut from a single sheet. That will self-assembly into an accurate surface. Much less work. :thumbup:
http://starship-enterprises.net/file...%20Pattern.jpg http://starship-enterprises.net/files/3f%20icosa%20Peel%20Pattern.jpg I can provide all the relevant edge lengths for a prolated ellipsoid. 'What do you think, sirs?' |
geodesic
The model has got to be as close a representation of the drawings as I can do,so as not to introduce any unknowns. The velocity and pressure profiles of a streamline half-body are dependent upon the compound curvature. Windshield wipers and roll-down windows would need more 'conventional' surroundings. ------------------------------------------------------------------------ IF a geodesic 1/3rd model were to appear in Ogden,Utah,September,2016,we'd be impelled to get it into the tunnel,and I'd sure help underwrite the cost.(hint-hint,wink-wink!) Plus,there's some pretty good Mexican food nearby.:) |
16-mods
The list is at home but here goes:
*reworked airdam with belly and edge radius *grille plug *improved cooling ductwork *reconfigured hood blister,widened out to edge of A-pillars,with NACA submerged-inlet /ventilation duct-to cowl inlet *faux GTP full-compound,triple-curvature windscreen *faux 'active' windshield wiper cowl area fairing *new mini-mirrors *mirror delete *faux flush glass *tape all seam and cut lines *full gap closure between cab and bed *restore missing belly pan section *add belly pans to lower A-arms *add urethane pan sections around rear axle gaps *faux 'active' wheel fairings(before and after front wheels) *ditto rear wheels *lowered diffuser addition to boat tail (2.8-degree) *add blended flow fence into lower perimeter to close in Coke-bottling *lower rear skirts to former full depth and add integrated flow fence *reconfigured aeroshell *reconfigured boat tail *reconfigured boat tail stinger (full-length) *simulated suspension drop (deflate the tires) Looks like I'm at 23 things to test,plus the model. |
I assume the "faux" components would essentially be non-functional and used for the wind tunnel test, but the other components would be functional for use when driving the truck?
faux
The windshield would have to be 'real.' I can't lower the truck so I'll just let the air out of the tires 'n see if it shows on the computer screen. Flush glass isn't going to happen.Nor a pliable cab/ bed gap-filler,or unit construction. Lots of Gorrilla tape and aluminum sheet,Formular,etc.,composite mockups. I will be able to simulate a 'future' in which these things were part of a production vehicle. |
Edit: Could I make a rear-steer reverse tricycle and put a ball hitch on a nose probe and have it track successfully, a least going forward? Wait a minute—42"x3 is 10' 6" wide. What size are your candidate wheels? |
tracking/wheels
----------------------------------------------------------------------------- The wheels are about 8.5" X 2.5". |
