Old 10-31-2008, 05:05 AM   #1 (permalink)
Modding for Eris
Thalass's Avatar
Stockie - '00 Outback GX
90 day: 21.25 mpg (US)
Wife's Car - '06 Corolla
90 day: 34.11 mpg (US)
Horse - '98 GPX-250
Backlight connected to instrument light?
Re: backlight brightness levels. Is it possible to change the backlight brightness with a potentiometer? The backlights in my instrument cluster are controlled that way, and it would be good if they could be controlled together.
Completely stock '99 Outback!
Electric 4WD on the moon! Win!
Old 10-31-2008, 07:39 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I added this to it's own thread cuz it is a neat idea and not iduino specific.
This is entirely doable, but you have to tap into your instrument panel lights, then figure out how big a resistor you need to drop the voltage down to 4.3 volts max (I think) on the backlight. I would assume a system voltage of 14 volts. Use 9.7 volts divided by the max backlight current (from your LCD datasheet) in amps, to figure out the minimum sized resistor needed.
Then unhook the existing connection to LCD 15 and hook up your resistor instead which leads to the light circuit that is controlled by the dashboard potentiometer.
Old 10-31-2008, 09:20 AM   #3 (permalink)
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
I also thought of using a photoresistor on an analog entry that will drive the brightness automatically. During the full day the LCD will be bright, during the night it will be darker, it would be linear and in "real-time" too.
Easy to do.
FYI on photoresistor:
Photoresistor - Wikipedia, the free encyclopedia
Old 11-05-2008, 03:22 PM   #4 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
If you just tapped into the instrument panel lights for the backlight source, wouldn't the backlight not turn on in the daytime (whenever the dash lights are off)? Is the LCD readable without the backlight on?
Old 11-05-2008, 08:08 PM   #5 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
McTimson, I would presume you are correct. What about making them dim when you turn on the lights. Just like most car stereos.
Old 11-05-2008, 10:44 PM   #6 (permalink)
If it's LED, a simple transistor circuit can be used to reduce the current for dimming. If it's CCFL or OLED, you'll have to somehow reduce the duty cycle of the inverter.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 11-07-2008, 12:43 PM   #7 (permalink)
McTimson's Avatar
Felix - '09 Yaris
I'm pretty sure they're LED, at least the one I have looks like it is.
It could easily be controlled with a separate potentiometer, if you were willing to do that. Connecting it to the same pot as the dimmer in your car would be a little more difficult.
But really, how often do you use the dimmer in your car? Maybe it's just me, but I've never had to dim my dash, I guess it just might not be that bright to begin with.
I think a separate potentiometer for the MPGuino would actually be better, because finding a sweet spot for the dashboard brightness and the backlight brightness would be hard with one pot controlling both, with 2 separate ones, you could fine tune each one to its' own brightness.
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 27 04-15-2010 12:41 AM
LED Refridgerator light bennelson Saving@Home 19 01-05-2010 12:06 AM
SGII backlight not working? ch00f Instrumentation 3 06-18-2008 03:22 AM
