Old 10-20-2008, 12:59 AM   #1 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
Question ---Backpressure in exhaust; good for city bad for highway!---
What i have been thinking;
Backpressure is good because it increases torque, so that is good for city driving where you need to constantly accelerate and decelerate.
But what about for constant cruising? When you dont need that torque... Wouldn't less backpressure be the best since air would flow out much better?
Old 10-20-2008, 01:08 AM   #2 (permalink)
Backpressure isn’t good for anything except when used for sound attenuation.
Old 10-20-2008, 01:51 AM   #3 (permalink)
Send a message via MSN to markweatherill
On a production car, 'back pressure' in the exhaust is factored into the cam timing. The exhaust valves can begin to open earlier than if an open exhaust was used, a benefit at lower engine speeds (i.e. in everyday driving).
Old 10-20-2008, 10:27 AM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
It's not about back pressure, it's momentum! the exhaust is exiting in pulses not a constant flow, if it was a steady flow then larger would be better, but your engine is not a turbine... and even with a turbine you have to tune your exhaust to keep the momentum to help the engine run better (at least the books on turbine design seem to say so), so what it boils down to is if you believe in physics a properly sized exhaust is going to treat you best, if you are 16 and were given a car, and failed math class then go with a larger exhaust.
Old 10-20-2008, 11:39 AM   #5 (permalink)
AeroGuy
eco_generator's Avatar
4x4 Wagon - '89 GL Wagon 4wd
Subaru
90 day: 31.58 mpg (US)
Fromeo - '07 Fit Base
90 day: 46.09 mpg (US)
You have some more reading to do...
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 36 04-01-2009 03:48 PM
Lugging the engine - good or bad for economy? landspeed General Efficiency Discussion 27 06-22-2008 08:47 PM
The Bad with the Good Lazarus The Lounge 1 01-31-2008 12:30 AM
