Old 04-26-2013, 08:33 AM   #61 (permalink)
Originally Posted by Miller88 View Post
I do like the AMC engines. The 2.5 was a pretty stout engine - a lot of low end torque for a 4 cyl. A MPI 2.5 wouldn't be a terrible idea ...
But a 6 cyl you'd be able to run taller gears.
Slap a turbocharger on the 2.5L and it can be set to outperform the 6-banger and eventually be able to run even taller gears
You might remember cam profiling can also do miracles for the torque band
AMC wiring was awesome! I remember as a kid, our CJ-7 caught fire on the way home from Christmas. And it wasn't more than a few years old!
That's why I'm quite over-concerned with anything regarding wiring. A random broken wire in a hard-to-detect spot can lead to a short-circuit, and then, you know...
Old 04-26-2013, 03:02 PM   #62 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
mmmm perty. thats got the curve in it to clear the bench seat
Old 05-18-2013, 10:05 AM   #63 (permalink)
Started getting the trans back together. Countershaft is in with the reverse/5th shift shaft. Time to start putting the mainshaft back together. Also out at Carlisle I picked up a wiring harness. Same thing as the painless kit but half the price. Very happy with it.
Burn lean and prosper \\ //
Old 05-18-2013, 10:16 AM   #64 (permalink)
Old 05-19-2013, 07:49 AM   #65 (permalink)
Nice to see the project advancing.
Old 05-19-2013, 11:09 AM   #66 (permalink)
Slowly but surely haha
Old 06-11-2013, 11:03 PM   #67 (permalink)
Trans finally back together. Used ford racing rebuild kit, new 2-3-and input/4 gears. Jeep bearing retainer to fit the amc bell housing. New 1-2 slider gear. New reverse idler gear. Next is engine rebuild
The Following User Says Thank You to slownugly For This Useful Post:
slowmover (06-14-2013)
Old 06-11-2013, 11:49 PM   #68 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Nice pic!
Originally Posted by slownugly View Post
slownugly (06-12-2013)
Old 06-12-2013, 11:39 AM   #69 (permalink)
New drivetrain. From backing plate to transmission yoke it cost about 1100 bux but it's worth it. Peace of mind
Old 06-17-2013, 05:34 PM   #70 (permalink)
"new" engine disassembled. It's at the spa getting machined and massaged. Meanwhile the frozen 199 came out. Finally feeling like somethings getting done. Ordering camshaft and lifters tomorrow.
Also I figured the gear ratio in the rear is 3.08. I plugged the gears into the calculator on 4lo.com. With the .68 overdrive in the trans I come up with about 1800rpm at 65 mph and 1900 at 70
