Basics of Bike conversion
I am searching for different motorcycle conversion tutorials. Our requirement is to obtain a speed of 150 km/hour. Two the point which I got so far:
[Sorry, I made a typo mistake used the bike instead please forgive and missed k instead I wrote mph instead of kmph. Now replaced both. Thanks and sorry] |
Bike? As in bicycle or motorcycle?
150mph...is that the correct unit? |
150 mph bike... I'd suggest V-Max; that torque is a BLAST!
150 mph bicycle... go with rocket power. |
First determine CdA drag. Second find where you can ride safely ride a motorcycle at 150 mph.
Hey, OP
Pretty obviously you had something else on your mind when you specified "150 mph motor." You can do 150 mph on a bicycle, but you have to be drafting the Pepsi Challenger dragster to do it. You can do 150 mph on a motorcycle, but you probably won't be able to fit the kind of motor it requires onto a bicycle frame. So please update this thread with what you actually meant when you said "150 mph." |
Look at his post history. |
Sorry it was a blunder from my side
Aha, better. 150kph is more reasonable :)
Moto
