Old 03-09-2018, 12:11 PM   #1 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 46.34 mpg (US)
Battery replacement?
So due to my use of P&G after dark, my battery is starting to not work right... I had to set aside(not track) a tank of fuel to charge the battery so I can reliably start again(tired of pushing the blasted thing)... any good info on possible LiFePO4 replacement? Or should I just get a deep cycle (wet lead acid) of the right size and call it good?
My current Ecotec project...
My last Ecotec project...
Old 03-09-2018, 12:13 PM   #2 (permalink)
Team Saturn
It doesnít help that all my lights are still incandescent and I use the radio at a good loud volume... aside from giving up radio or coasting with switch in ACC only(until right before I restart) I donít know what to do short term...
Old 03-09-2018, 12:18 PM   #3 (permalink)
You don't trickle charge or charge when you get home?
Daschicken (03-26-2018)
Old 03-09-2018, 12:19 PM   #4 (permalink)
V8 guy
Shocker - '11 Nissan Leaf SL
90 day: 130.28 mpg (US)
Unless you are going to relocate the battery away from the hot engine compartment, don't even think about LiFePO4.
2011 leaf SL, white 240v evse mod, trailer hitch, new batt as of 2014.
Old 03-09-2018, 12:23 PM   #5 (permalink)
Team Saturn
No charger with which to do so, and no outdoor receptacles to plug into anyway
Stock battery location is in the spare tire well, sooo...
Old 03-09-2018, 01:14 PM   #6 (permalink)
EcoModding Newb
90 day: 31.25 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 79.06 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 28.01 mpg (US)
I like this one:
LiFePO4 Prismatic Battery: 12.8V 20Ah (256Wh, 10C rate) (24.0) - UN38.3 Passed (DGR)
Keep in mind it isn't to be charged when below freezing, so hopefully locating it inside the cabin will prevent that situation.
Radio shouldn't matter much, but you should replace your lights with LED. Don't bother with the blinkers though.
If you buy from batteryspace, there are usually 10% off codes that should at least cover shipping.
Keep in mind this battery likely has half the capacity of your pb battery when it was new. It can handle deeper discharging on a regular basis, but doesn't like very deep discharging.
Old 03-09-2018, 01:26 PM   #7 (permalink)
Supra - '88 Toyota Supra
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 18.75 mpg (US)
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
I would upgrade the blinkers too if your car uses the blinkers as driving lights. As far as lithium batteries I highly recommend them in the warmer weather. During the summer I run a lithium motorcycle battery that I got off Amazon for $100 it only weighs 2 lbs and has no problem starting my car I would even say it cranks over faster than the standard battery but it doesn't have much reserve capacity
Old 03-09-2018, 01:46 PM   #8 (permalink)
Team Saturn
I like this one:
Canít charge it below freezing? That wonít work, as I park outside and my cabin can remain below freezing several minutes into my commutes... I do wanna go LED for my lights and a switchback led for my front turn signal/ DRL... trying to find a decent LED 9007 bulb, as projectors are a little too rich for my blood at the moment
Old 03-09-2018, 01:54 PM   #9 (permalink)
Custom User Title
Gasoline Fumes's Avatar
Nut Wagon - '91 Honda Civic Wagon DX
Wagons
90 day: 63.53 mpg (US)
CRXFi - '88 Honda CRX XFi
You need to charge the battery more (alternator or grid) or reduce electrical draw. No battery will give you more power than you put into it.
Best tank with the Honda so far is 81 MPG.
Old 03-09-2018, 04:00 PM   #10 (permalink)
Easy test is no radio then see if situation improves.
Xist (03-09-2018)
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
