Old 01-10-2009, 05:51 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Battery Safety
With all of us tinkering in one way or another with electric vehicles, what steps can be taken to protect yourself or your vehicle from damage caused by the battery pack in case of an accident.
For example, lets say due to poor planning basjoos had a battery bank in the boattail of his civic. He gets rear ended and two things could happen;
1. Battery acid leaks out damaging components, (Minor)
2. Batteries are twisted in ways that terminals either touch or short against other metal causing sparks which can ignite interior components.
Are these outlanding scenarios or are their ways to safely house the batteries in our converted vehicles ....
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 01-10-2009, 06:10 PM   #2 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
I've seen enough batteries blow up/vent gasses/spray acid all over everything, that when I do my EV I'll definitely seal any battery chamber in the car, and vent the chamber to the outside.
I once had a lawn/garden battery I was charging spray me in the face good when I pulled a cap to check acid levels - the vent tube was blocked! I was really glad that I wore glasses!
...sure cleaned 'em up good...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 01-10-2009, 06:14 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
You could also put a fuse inline between each battery/module if you were so inclined. That would minimize the effects (duration) of a short.
Old 01-11-2009, 06:27 PM   #4 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Safety precautions should be taken with batteries just as they should with gasoline.
It just makes sense to use fuses, have batteries solidly bolted down, prevent anything from shorting the terminals, etc.
Simple, reasonable precautions are all that's necessary.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-11-2009, 06:30 PM   #5 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
My safety policy:
Don't touch the red wire to the black wire.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 01-12-2009, 12:14 PM   #6 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
My commuti-car battery box was factory built with an aluminum plate box holding the batteries mounted with the bolts in slots instead of tight holes so if it's hit by another vehicle it can move up to a foot before coming in contact with other parts of the vehicle.
battery boxes should be covered and vented to the outside of the vehicle, they should also have a way to hold the batteries in place if the vehicle flips over or is hit, I've seen main battery cables run thru rubber hose as an extra insulator when they are run thru fire walls or near the other cables or areas that they might get abrasion from.
You just need to remember that your batteries have enough energy in them to move your vehicle for many miles, and you don't want that energy to be released all at once.
Old 01-12-2009, 01:48 PM   #7 (permalink)
Intrigued's Avatar
Originally Posted by The Atomic Ass View Post
My safety policy:
LOL! Excellent policy!
...otherwise it'll be one of those "Hey, watch this!" moments...
Old 01-12-2009, 01:53 PM   #8 (permalink)
Intrigued's Avatar
Excellent points all. I wish I had the money to buy one of the several of those I have seen on eBay...
Old 01-12-2009, 07:18 PM   #9 (permalink)
Christopher Jordan's Avatar
Gopher (aka- go fer...) - '95 Aspire 2dr hatch
My safety policy:
My City-EL is a confusing mess of primary,secondary, and all that unnecessary computer charging circuitry. One of the first things I did was unclip a battery post and tried to hook up a "start" booster since those 4 batteries won't hold a charge worth beans!.
Shower of sparks! Lots of wired are scorched and taped up; so maybe I did touch the red to black!
This morning everything was fine until I backed into the garage. Last few inches- click; *BAM* - right into the wall. Maybe I should put the red and black wires together intentionally and put it out of its misery!
Old 01-12-2009, 07:34 PM   #10 (permalink)
bennelson's Avatar
S10 - '95 S10
I guess I would say that labeling all battery posts and wires would also be a safety feature.
They really all do look the same, and it is easy to confuse wires that should not touch, with those that should.
My YouTube Videos
LiFePo4 battery supplier ken102282 For Sale 23 12-16-2008 12:04 AM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 04:35 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 10:13 PM
"Sonata" Lithium Ion battery NeilBlanchard General Efficiency Discussion 0 09-08-2008 04:19 PM
Battery Jumper Alt use? WaxyChicken Off-Topic Tech 5 04-06-2008 02:26 AM
