Old 10-06-2008, 04:51 AM   #1 (permalink)
Send a message via MSN to markweatherill
Battery to starter cable fault
I have what appears to be a faulty cable from the battery to the starter. It's been turning the engine over slower and slower until finally I had to investigate. Wiggling the end of the cable at the starter appeared to fix the problem for now.
I will renew the cable ASAP. But meantime could this also be the cause of a general lack of power? At the same time as the starter began churning slowly, the engine seemed to have no real 'go' on the open road. Is that possible?
Old 10-06-2008, 10:40 AM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
check the ground cable too, there should be one between the frame and the engine block as well, I've seen starter cables burn out before, not real common but it happens.
Old 10-06-2008, 01:41 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Possible depending on the vehicle. At least on mine, the starter is acts as a junction block as well. The alternator cable goes to the starter, then goes to the battery. So if that cable was bad, the battery would run down, and it would run worse due to low voltage problems.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-06-2008, 03:39 PM   #4 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Cleaning all your grounds/connections should help. I've never heard of a cable being bad, just rust/oxidation on connections
Old 10-09-2008, 02:12 AM   #5 (permalink)
It wasn't the main battery cables after all. It appears to be the wire frm the 'M' terminal into the starter itself. Of course I can *see* it but can't reach it without some major dismantling...
cheap, light-weight EV battery? eta Fossil Fuel Free 5 05-15-2009 02:00 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 10:13 PM
Alternator Delete VS starter motor bennelson EcoModding Central 23 09-04-2008 08:32 PM
Starter went out millenniumtree EcoModding Central 9 08-25-2008 12:15 PM
Split battery power apgrok1 EcoModding Central 3 03-13-2008 10:59 PM
