Old 09-28-2009, 11:43 AM   #11 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I agree with Funny to make it removable. There is really no reason to go to rivets. Regular fasteners work just fine.
Old 09-28-2009, 01:50 PM   #12 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
I'd try using rivnuts in existing subframe and underbody holes.
www.HyperKilometreur.com - Quand chaque goutte compte...
The Following User Says Thank You to tasdrouille For This Useful Post:
TomO (09-28-2009)
Old 09-28-2009, 03:42 PM   #13 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 43.34 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
That is a slick product!
RIVNUTS <-- there is some info on them there.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 09-28-2009, 04:33 PM   #14 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by snydertalon View Post
I wish I could say that was my install. That is Daox's. But i agree, very clean.
I will look for a rivet gun. How easy is it to remove for maintenance?
I didn't know this was Daox's car. I'm just familiar with the Paseo that he has.
( How did I miss that thread ? )
About the rivet idea, I agree with everyone else here about not using them for anything that might need to be removed.
I riveted my pan ( engine pan ) together since it was two sections of aluminum, but I use self tapping screws to actually hold it to the car.
In case I need to change my oil, or any such thing as that, a few screws are all that needs to be removed.
Rivets hold super tight ( After all, rivets are what hold planes together )
Once in place, they are there for good.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Honda Fit Belly Pan Project Fit Aerodynamics 15 03-10-2011 05:32 PM
Aerodynamic Belly Pan on Toyota Echo jimepting Aerodynamics 23 12-05-2010 07:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 07:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 09:14 AM
