Submit Tools LinkBack (1) Thread Tools
Old 09-27-2009, 08:12 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
04 Accord - '04 Accord EX
90 day: 34.48 mpg (US)
Belly Pan
So i've been working on my belly pan, and I have it cut pretty close to non-machined perfect. The tow hooks and oil pan have access, its fits in snug. I am rather proud of how it turned out.
FAIL. How the ** do I connect it? I talked to the guy at Lowes and he suggested some plastic push thing that works like drywall anchors. Except the whole it doesn't work.
From Daox's Matrix Build thread, where did he get these
or these
Or what are they even called so I can go find a place that sells them.
Stupid areoclips makes me wanna.........
Thanks for the help
Old 09-27-2009, 09:53 PM   #2 (permalink)
Hypermiler
brucepick's Avatar
Sven - Volvo 240 wagon (semi-retired) - '89 240 wagon
90 day: 25.57 mpg (US)
Lean Burn Civic - '97 Civic HX
90 day: 42.76 mpg (US)
Hmmm. Try a pm to Doax.
I've started using rivets for some of this type stuff, with fender washers like you see in the photos above wherever there's plastic. I can't tell for certain if those are rivets but they look like they might be. If fastening plastic to plastic I'd use a wide rivet like that on both sides, otherwise the rivet will just pull right through. I found that 5 mm. (3/16") rivets go well with some standard size washers I found.
Rivet gun is maybe $15 or so?? Rivets are not too much - a few dollars for a small box.
Driving Lean Burn '97 Civic HX with tires at 50+ psi. '89 Volvo 240 is semi-retired. I did love that car though!
Old 09-27-2009, 09:56 PM   #3 (permalink)
Cd
no
Cd's Avatar
Very , very nice.
Very clean and professional.
I think he might have been refering to dzus fasteners.
I work at BLowes, and we don't carry them. ( At least not in my particular store. )
Actually, it looks like you already have them on the grille block. There are several types of push fasteners. Check the pull out drawers in the hardware department. You might find something useful there.
I just used self tapping screws and drilled into the frame ... but I don't drive a brand new car like you, so ....
Old 09-27-2009, 10:00 PM   #4 (permalink)
Cd
no
Cd's Avatar
Harbour Freight has some really good deals on rivet guns - less than half the price of the ones at Lowes. At Lowes, we don't carry plastic riveters either, but I saw one at Harbour Freight ( complete with something like 30 1/4" plastic rivets for something like twenty bucks.
Good luck.
Old 09-27-2009, 10:14 PM   #5 (permalink)
Originally Posted by Cd View Post
Very , very nice.
Good luck.
I wish I could say that was my install. That is Daox's. But i agree, very clean.
I will look for a rivet gun. How easy is it to remove for maintenance?
Old 09-27-2009, 11:41 PM   #6 (permalink)
Fasteners
you can get Dzus style quarter turn fasteners at jegs.com or just search for "Dzus fasteners"; but you still have to rivet in the little wire nutplate things that the Dzus head grabs on to.
Old 09-27-2009, 11:48 PM   #7 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
Haha, I'm glad my simple grill block has inspired you.
Those are simply thumb screws with fender washers. They attach to another fender washer and wing nut on the back side. I wanted to keep it a tooless design in case I needed to remove them on the road. I picked them up at the local home improvement store I believe. Any good hardware store should have them too.
Thumb screw:
The screws on the bottom are just a fairly good sized phillips head screw and fender washer. I drilled holes in the bumper cover and let the screw do the tapping work. They hold great.
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Old 09-28-2009, 12:06 AM   #8 (permalink)
that was demoralization simple.
I am going to take other peoples advice and try the rivet idea. Are there such things as removable rivets?
Old 09-28-2009, 03:20 AM   #9 (permalink)
vectra a - '95 Vectra GLS
90 day: 34.9 mpg (US)
rivets are usually quite permanent, but aluminum pop rivets can be drilled out again without much damage to the surounding material.
for most underbody work in plastic or alluminum i use self tapping wood screws or sometimes nuts and bolts as these can always be undone with simple tools.
aer·o·dy·nam·ics:
the science of passing gass
Old 09-28-2009, 11:10 AM   #10 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 41.96 mpg (US)
I wouldn't use rivets, they are far too permanent for the application of a belly pan. What happens if you need to get to the underside of the vehicle for a repair, wasted minutes of work removing rivets and possibly damaging the belly pan? I would use self tapping hex head screws and fender washers, they are less likely to damage the belly pan, are easier to take off when repairs are needed, and with the fender washers, are more likely to hold the belly pan against the body without the pan getting pulled off (like if you bottom out).
American by right
Ecomodder by choice
Hypermiler by necessity
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/belly-pan-10357.html
Posted By For Type Date
Belly Pan - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-27-2009 09:55 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 07:27 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 17 06-07-2009 01:07 PM
Aerodynamic Belly Pan on Toyota Echo jimepting Aerodynamics 13 03-12-2009 05:21 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 09:14 AM
Honda Fit Belly Pan Project Fit Aerodynamics 6 01-13-2009 06:39 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
