Old 02-07-2010, 03:17 PM   #11 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
When you want free ventilation, you have to be sensitive to the air. Good ductwork can cost more than fans, and it is bulky, so you don't see a lot of it. The air exiting the cooling chamber won't want to accelerate instantly. It needs a nozzle, or in this case, a flat, tapering duct. Unlike the nozzle in a paint-spray gun, it will only be getting help from one side to sweep the exiting air away and make room for more. Fortunately, if the intake is nicely placed and well-ducted and sealed, there should be lots of pressure difference to help. In planning the belly pan, leave clearance for that air all the way back. It will be a sudden thickening of the boundary layer.
Old 02-07-2010, 04:59 PM   #12 (permalink)
Originally Posted by Rokeby View Post
The issue here isn't the shape of the cooling air exit opening. It is the most
effective -- or least harmful -- direction for the air to be moving as it passes
through the belly pan.
That makes perfect sense. You need that arc to ease the angle of airflow into the air traffic flowing under the car.
There is another interesting element in the picture, the vertical air dam in
front of the exit opening. I suspect this is to make a low pressure area
behind it for the exiting cooling air to fill.
Yes, i didn't notice that on first glance. Although it would seem to me that a curved piece would be better than flat in almost any case. But experts please chime in.
Old 02-07-2010, 05:10 PM   #13 (permalink)
So, perhaps it's hard to generalize, but should the exhaust vent be bigger in area than the intake?
So similar to the air dam that Rokeby posted? The car is going to be low to the ground in the front, perhaps 6" or less, will that have an impact? Would giving the truck a forward rake of about 6" help or be a good enough substitute?
Old 02-08-2010, 02:09 AM   #14 (permalink)
Presumably, the entry and exit holes will be passing equal volumes. Size them according to the velocity you want to match them to. The slicker the bottom, the faster the flow there. A bit of rake is a cheap, partial fix for this and other common issues.
belly pan, fan, grill blocking
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/belly-pan-fan-concept-12206.html
Posted By For Type Date
Solar panel direct charging guide - Page 5 - DIY Electric Car Forums This thread Refback 02-15-2010 08:18 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Honda Fit Belly Pan Project Fit Aerodynamics 15 03-10-2011 05:32 PM
Aerodynamic Belly Pan on Toyota Echo jimepting Aerodynamics 23 12-05-2010 07:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 07:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 09:14 AM
