Old 09-08-2008, 06:14 PM   #101 (permalink)
Originally Posted by COMP View Post
could that be a safety thing to ?
It looks as though they are on every articulated bus in LA.
Style??? Efficiency???
As for the zigzag tape, after reading the article on the glider and seeing the enhanced photographs I do believe they work. Their benefit is likely too small to be lost in the every day driving and I suspect that you do not have acces to a wind tunnel and enhanced photography.
Instead of a tuft test try a thread test and use shorter threads?
Originally Posted by bbjsw10 View Post
Absolutely beautiful pictures. I just wish some where higher def so I could use as a desktop.
PM me and let me know which you like and I will send you full resolution pix.
Old 09-08-2008, 09:27 PM   #102 (permalink)
- - '010 Prius III w/Navi
Hi All,
I drove around for a week with tufts behind turbulators the upper 1/3 of one A- pilar. When the conditions were windless, one could see the tufts flowing horizontal on the turbulator side without any motion. On the side without the turbulator the tufts were trailing with about a 15 degree up angle and with some small oscillating motion.
Even slight cross winds completly changed this, however. If the wind came across the car, to the turbulator side, the tufts ran at a 15 degree or more up angle. So, the turbulator benefit was lost completely.
Based on this, I put turbolators on both sides of my Prius. Still, I think there is a possibility that drag is incressed with the Prius.
On cars with higher windshield rakes, the advantage may be more. The issue is that the air is pushed sideways around the edge of the A-pilar. In the Prius the air is at about a 60 degree up angle across the windshield. In other cars it may be more horizontal. When the flow into the A-pilar area is horizontal and pushes out into the slip stream by its own momentum, it will begin to turn over, and turn into vortex. The purpose of the tubulators is to use the cross flow momentum to trip the air into a slip-stream direction.
My guess is there may actually be an optimum windshield angle for vortex formation. Anybody have any info on this? Aerohead ?
Old 09-08-2008, 09:51 PM   #103 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
edbso -
Originally Posted by edbso View Post
It is OK to disclose this now.
Beautiful picture. I love prototypes. Reminds me of the Audi A3 wagon or the Volvo C30.
Mini Wagons Unite!
CarloSW2
American Solar Energy Society
Old 12-01-2008, 04:52 AM   #104 (permalink)
EcoModding Lurkaholic
Tercelerat0r's Avatar
White Wallace - '91 Tercel DX
90 day: 28.44 mpg (US)
Trugly - '92 P'Up
90 day: 23.66 mpg (US)
Belly Pan FTW!
Old 06-12-2010, 11:27 PM   #105 (permalink)
Import Tuner
ac was off.
I just wanted to give everyone the heads up on something ....sealing off the grill and under carrige can change the pressure in your engine and cause it to over heat.
Browser Warning
Old 06-13-2010, 02:40 AM   #106 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
I think it's mostly high engine temperatures that worry people the most..
That's why most folks closely monitor the engine temperature after making
a grill mod etc.. If it gets too warm, they let in more air..
Cheers,
Rich
Old 06-13-2010, 09:30 PM   #107 (permalink)
Undecided - '96 Civic HX
Last 3: 38.01 mpg (US)
Nice idea for the underbelly, but why use lexan for the back half?
Old 08-09-2010, 12:02 AM   #108 (permalink)
Simply to smooth the air exiting the car.
Plus there is what I call a "French Air Brake" that hangs down and disturbs the air. Not my car but it shows the piece hanging down.
I am exceeding the EPA and I like to drive the speed limit plus 5 mph.
Old 08-17-2010, 02:15 AM   #109 (permalink)
aerobrick - '04 Dakota Quad Cab SXT
edbso,
What did you use for screen material. Regular al window screen or heavier stuff?? Any edging or just loose wires?
Don
Old 08-17-2010, 02:57 AM   #110 (permalink)
How long until the crash?
great stuff
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/belly-pan-vortex-generators-1209.html
Posted By For Type Date
Road Trip! ROAD TRIP!! 13,433 Km 8,347 Mile Road Trip!!! - AACA Forums This thread Refback 12-16-2011 03:51 PM
Slant Six Forum, :: View topic - Aero question This thread Refback 04-15-2011 06:11 PM
My Matrix Eats Too Much Gas. - Toyota Matrix Owners Forum - Page 2 This thread Refback 03-29-2011 02:21 AM
Dynamo Label Maker: Dynamo Label Maker Photos, Wallpapers, Galleries, DYM12966 1 1 JPG This thread Refback 03-02-2011 04:54 PM
Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-29-2010 10:23 PM
Toyota Matrix Owners Forum > My Matrix Eats Too Much Gas. This thread Refback 04-28-2010 01:17 PM
Vortex generators on Dragon Wings - Rotary Wing Forum This thread Refback 03-28-2010 07:26 PM
Vortex generators on Dragon Wings - Rotary Wing Forum This thread Refback 03-17-2010 06:58 AM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 12-04-2009 12:17 PM
My Matrix Eats Too Much Gas. - Toyota Matrix Owners Forum This thread Refback 12-04-2009 12:13 PM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-31-2009 10:18 AM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-23-2009 05:53 AM
Nabble - Re: Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-22-2009 09:40 PM
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 63 06-02-2011 04:22 PM
Metro undertray / belly pan MetroMPG Aerodynamics 33 10-15-2009 12:33 AM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 02:09 PM
More than one Vortex too! Christopher Jordan Fossil Fuel Free 2 02-17-2008 08:57 PM
Plant Stand Vortex Generators? cfg83 Aerodynamics 7 02-15-2008 12:11 AM
