Old 05-31-2008, 01:27 PM   #31 (permalink)
Originally Posted by COMP View Post
where did you get that ???
Ditto!
BTW, if you can find or make tape of the right thickness, you can easily make zigzag tape with pinking shears.
The guys who sell zigzag tape to the sailplane crowd will only sell it in compete rolls, or so they say.
Maybe you could make dimples by making spots of clear silicone bathtub caulk from a tube, dabbed on. This might effectively duplicate the dimples that BMW and others cast onto their mirror housings, as seen in the E36 325i et al.
Old 05-31-2008, 11:42 PM   #32 (permalink)
Heh, the missus has a slew of crafting scissors that can make any type of zig-zag imaginable. I'm making me some of this .
Old 06-01-2008, 12:09 AM   #33 (permalink)
The stuff they use on sailplanes is pretty thick, maybe 0.030" or more. You might want to layer the tape to that thickness, then cut it with pinking shears.
FWIW, the sailplane stuff has the innie and outie zizgags parallel, if that makes any difference.
The little turbulator bumps on my Bimmer 3 Series mirror housings are about the same height, i.e., ~0.030".
I suppose the turbulator has to be a given height to trip the flow optimally.
Old 06-01-2008, 01:30 AM   #34 (permalink)
Blue - '-1823 P/U
what kind of tape are you going to use ???
Old 06-01-2008, 02:43 AM   #35 (permalink)
Don't know. What's weather resistant and sticks to auto paint?
Old 06-01-2008, 03:43 AM   #36 (permalink)
Why not use the pinking shears and tape to make a zigzag stencil, then put on some clear silicone bathtub caulk as the turbulator, peeling off the stencil before the caulk firms up. That caulk is transparent and has a ~50 year life, so you wouldn't have to paint it. Build up in layers to desired thickness. Tough stuff.
Old 06-01-2008, 09:58 AM   #37 (permalink)
Blue - '-1823 P/U
and how thick does it need to be to work ??? also want to be able to wax ??
Old 06-01-2008, 05:57 PM   #38 (permalink)
- - '010 Prius III w/Navi
Hi Edbso,
I think that is a good idea. Even the Prius has the vortex at the top of the A-pillar. I can see the swirling/stagnation of the rain on the driver's window there. Some concept next generation Prius have shown side dams there. But, that is allot of extra drag possibly, due to the air going sideways, and not up over the roof axially. So, putting in a turbulator is probably just the thing. It will chop up the big vortices into little ones, which have less cross-section (boundary layer height). At least that is my guestimate of why its quieter.
The Following User Says Thank You to donee For This Useful Post:
Cd (06-13-2010)
Old 06-01-2008, 07:01 PM   #39 (permalink)
Came from the glider sail plane area.
So I found this interesting piece about work being done on the airflow over a glider wing
What particularly impressed me was the lightness of the material, Zig-Zag tape. AND it works.
I also took the opinion that if I made a big error in placement there likely would not be huge negative effects.
To help visualize how the laminar bubble would look during qualitative wind tunnel cession the testor used vaseline plus TiO2 mixing as a surface liquid for visualization. The result could be clearly seen thanks to UV light.
The before shot of disturbed air flow over the wing.
Now the attempts and final fix.
Starting with straight tape...not much result.
Now Zig-Zag tape placed on a diagonal too test for positioning. Big improvement in areas.
And the final result.
I think that the results are dramatic and IF one makes a huge error in placement I don't think that there will be a huge negative effect.
When I put the tape on the rear view mirror I couldn't tell that there was a difference. When I put it on the A pillar the reduction of the air aka wind noise was dramatic. A huge improvement.
So in summary...
It appears to work...
It is inexpensive (Dymo tape) cut with pinking sheers...
It is light and
I like that it is "quirky".
Old 06-01-2008, 07:19 PM   #40 (permalink)
This is the airflow that I have over the A pillars.
Basically horizontal so I placed the tape perpendicular to the flow.
I hope that I have energized the air across the side windows. Should be able to tell during a rainy day.
I also have to wonder whether a positive effect can be had by placing the Zig-Zag tape at the trailing edge of the Matrix?
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/belly-pan-vortex-generators-1209.html
Posted By For Type Date
Road Trip! ROAD TRIP!! 13,433 Km 8,347 Mile Road Trip!!! - AACA Forums This thread Refback 12-16-2011 03:51 PM
Slant Six Forum, :: View topic - Aero question This thread Refback 04-15-2011 06:11 PM
My Matrix Eats Too Much Gas. - Toyota Matrix Owners Forum - Page 2 This thread Refback 03-29-2011 02:21 AM
Dynamo Label Maker: Dynamo Label Maker Photos, Wallpapers, Galleries, DYM12966 1 1 JPG This thread Refback 03-02-2011 04:54 PM
Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-29-2010 10:23 PM
Toyota Matrix Owners Forum > My Matrix Eats Too Much Gas. This thread Refback 04-28-2010 01:17 PM
Vortex generators on Dragon Wings - Rotary Wing Forum This thread Refback 03-28-2010 07:26 PM
Vortex generators on Dragon Wings - Rotary Wing Forum This thread Refback 03-17-2010 06:58 AM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 12-04-2009 12:17 PM
My Matrix Eats Too Much Gas. - Toyota Matrix Owners Forum This thread Refback 12-04-2009 12:13 PM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-31-2009 10:18 AM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-23-2009 05:53 AM
Nabble - Re: Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-22-2009 09:40 PM
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 63 06-02-2011 04:22 PM
Metro undertray / belly pan MetroMPG Aerodynamics 33 10-15-2009 12:33 AM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 02:09 PM
More than one Vortex too! Christopher Jordan Fossil Fuel Free 2 02-17-2008 08:57 PM
Plant Stand Vortex Generators? cfg83 Aerodynamics 7 02-15-2008 12:11 AM
