Old 02-27-2008, 11:02 PM   #1 (permalink)
Belly pan or vortex generators?
This is the underside of my Toyota Matrix.
What concerns me is the big step down from the subframe to the factory floor pan.
Should I try and smooth this out with a new floorpan or put vortex generators on the subframe?
Or just leave well enough alone.
I do plan on closing the holes with stainless steel tape.
Your thoughts will be appreciated, Thanks
Old 02-28-2008, 01:01 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I would go for the full belly pan in this situation, I would think.
Welcome to the site!
Old 02-28-2008, 01:03 AM   #3 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Belly pan.
Vortex generators WILL NOT fix the turbulence you have down there
Challenge me, or correct me, but don't ask me to die quietly.
Old 02-28-2008, 11:09 AM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I agree with them both. Come summer my Matrix will definitly be treated to belly pan in front, and hopefully in back too.
Old 03-22-2008, 07:44 PM   #5 (permalink)
rookie
The full length body pan is unquestionably the better option. And vortex generators on the subframe will do little.
However, here's something you can try. If you've got a smooth pan under the nose of your front end, and it extends back to/under the engine compartment, and it's LOWER THAN THE SUBFRAME (and anything else in the area), you can place some VG's at the trailing edge of the pan to energize the airflow under the car. It doesn't keep air totally away from the rough surface of the underbody, but it will provide some deflection at speed.
Old 03-22-2008, 11:47 PM   #6 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
^true that
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 03-23-2008, 12:37 AM   #7 (permalink)
Instead of vortex generators, why not try flow fences? Some L angle aluminum of ~2" height, or equivalent in plastic, would tell us. Or, PVC 2" X 2" square rain spout from Home Depot, cut diagonally along its length into two L pieces, then screwed or glued to the belly of the vehicle, would work.
Old 03-23-2008, 12:55 AM   #8 (permalink)
yea.. you should see mine. clumps of dirt fall off when working under there... oh wait what's this... A LIVE POSSUM!?!?!?!?!
Old 04-30-2008, 02:43 PM   #9 (permalink)
OK so I am taking your advise on the full belly pan.
So far I have covered from the front bumper to about 4" behind the front wheels. I used lexan. Reasonably easy to work with and durable. Difficult to photograph, I will work on better pictures.
I also am using a grill block. 3" grill block. OK it is actually 3" wide tape. I have left one row of openings free in the top grill and 2 open in the bottom grill.
Around town the underhood temperature is around 120F and goes down to ambient temperature at highway speeds.
I figure that I am good to go to the rear axle but over it and on to the rear bumper????
EPA mpg Highway 28 mpg
Recently observed on the highway with cruise set at 70 mph 31.5 miles per American gallon.
37.87 miles per Canadian gallon.
ac was off.
Old 05-11-2008, 02:25 AM   #10 (permalink)
The proces continues
So I have decided to do the area between the front pan and rear axle with screen that is glued and screwed in place.
in process and after ...
With all of the screen in place I painted it with a couple layers of paint with a roller and have sealed 1/2 or so of the holes.
Tomorrow or soon I will hit the area with under coating.
Next the area from the rear axle and back bumper. I think Lexan will be the best answer there.
Wind noise is reduced .
The car also feels "lighter" and only slightly a bit darty. Could be my imagination or simply different road surface influencing the driving feel.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/belly-pan-vortex-generators-1209.html
Posted By For Type Date
Road Trip! ROAD TRIP!! 13,433 Km 8,347 Mile Road Trip!!! - AACA Forums This thread Refback 12-16-2011 03:51 PM
Slant Six Forum, :: View topic - Aero question This thread Refback 04-15-2011 06:11 PM
My Matrix Eats Too Much Gas. - Toyota Matrix Owners Forum - Page 2 This thread Refback 03-29-2011 02:21 AM
Dynamo Label Maker: Dynamo Label Maker Photos, Wallpapers, Galleries, DYM12966 1 1 JPG This thread Refback 03-02-2011 04:54 PM
Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-29-2010 10:23 PM
Toyota Matrix Owners Forum > My Matrix Eats Too Much Gas. This thread Refback 04-28-2010 01:17 PM
Vortex generators on Dragon Wings - Rotary Wing Forum This thread Refback 03-28-2010 07:26 PM
Vortex generators on Dragon Wings - Rotary Wing Forum This thread Refback 03-17-2010 06:58 AM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 12-04-2009 12:17 PM
My Matrix Eats Too Much Gas. - Toyota Matrix Owners Forum This thread Refback 12-04-2009 12:13 PM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-31-2009 10:18 AM
Nabble - Electric Vehicle Discussion List - Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-23-2009 05:53 AM
Nabble - Re: Mythbusters: Golf Ball Effect improves aerodynamics This thread Refback 10-22-2009 09:40 PM
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 63 06-02-2011 04:22 PM
Metro undertray / belly pan MetroMPG Aerodynamics 33 10-15-2009 12:33 AM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 02:09 PM
More than one Vortex too! Christopher Jordan Fossil Fuel Free 2 02-17-2008 08:57 PM
Plant Stand Vortex Generators? cfg83 Aerodynamics 7 02-15-2008 12:11 AM
